Question about HP Photosmart C3180 All-In-One InkJet Printer
Message says envelope is the wrong size
Nine times out of ten, when printing an address on an envelope, I receive a message that the envelope is the wrong size. The envelope is the right size. Usually if I press "resume" the address is then printed properly; sometimes the envelope is sent through without printing, but if I put it in again & click on print, it will go through.
  • Anonymous Mar 22, 2014
    #10 envelope prints only the address at top of envelope.
DOWNLOOD PRINTER DRIVERS C3183
Posted on Jun 19, 2008
    Sergeant:
  • 390 Answers
I would go for a quick fix and uninstall the printer and reinstall it. But first, just try resetting it by turning it off, unplugging all cables and usb cords, replug it and turn back on. If no good, then do the above. Good luck.
Posted on Aug 30, 2007
SOURCE:
Hi! I have a LaserJet Pro MFP 476nw. When I go to print an envelope using the automatic envelope feeder in the front drop down door, I get the message Clear jam in tray 2.
Go to your menu and pick that cassette out and make sure it is set to the proper size envelope. ten to one it is not os it shows a jam cause it is looking for another size.
Mar 27, 2018 | HP LaserJet Office Equipment & Supplies
Print Shop 23.1 printing problem
Does that happen only with Print Shop, or any way you try to print, please?
Are you really a message with the exact wording (to) keep printing or what?
Are you really seeing a message with the exact wording (to) turn off envelope printing size of printer and use reg. paper size or what?
Nov 29, 2017 | Computers & Internet
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Dec 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Envelopes trigger ''wrong paper size'' every time in hp 1510
Have you made sure to choose the correct (matching) envelope size in your software?
Dec 01, 2009 | Office Equipment & Supplies
HP Photosmart Premium c309a series will not print envelopes. I keep getting an error message that says paper mismatch. It doesn't matter what size envelope I put in, it always gives me an error message....
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Sep 21, 2009 | HP Photosmart Premium C309A All-In-One...
Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
CAN'T PRINT ENVELOPES ON HP PSC 2310
hi friend here is link for your 24 hour online technisoin is tehre here is lin for it u can chat with him he will guide u what do technision
http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&lang=en&product=500508&dlc=en
Apr 13, 2008 | HP PSC 2410 All-In-One InkJet Printer
MESSAGES
It largely depends on what model of switch the phones are connected to, however here are some links to user card and voicemail instructions, hope it helps.
http://www142.nortelnetworks.com/bvdoc/norstarbcm/t7316uce03.pdf
http://www142.nortelnetworks.com/bvdoc/norstarbcm/nvm4_reference_guide.pdf
To listen to your messages:
A number of options are available to you during and after listening to a message.
The table “Listening to your mailbox messages” shows the options and when they
are available.
1. Press ƒ·°⁄ to open your mailbox.
2. Enter your mailbox password and press OK or £.
3. Press PLAY to listen to your messages. For options,
refer to the table "Listening to your mailbox
messages".
4. Press ® to end the session.
Option Button Available
while
listening to a
message
Available
after
listening to
a message
Description
Backup ⁄
or
X Rewinds the message nine seconds and
resumes playing it from that point.
Copy fi
or
COPY
X X Sends a copy of the message to one or more
mailboxes. When you record the introduction
to the forwarded message, the introduction
must be more than three seconds long.
End of
Message
or
X Skips to the end of the message.
Envelope † X X Plays the information on the message envelope.
Envelope information includes the date and
time the message was sent and, if the message
was internal, the directory name of the sender.
This option is not shown on the display.
Erase °
or
ERASE
X X Deletes the message currently being played or,
if no messages are playing, deletes the
message just played. Deleted messages remain
in your mailbox until the session is ended.
(Refer to Notes 1. and 2.)
Forward ‹
or
X Advances the message nine seconds and
continues playing from that point. A message
can be forwarded as many times as required.
Feb 01, 2008 | NorStar T7316E Corded Phone
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
Feb 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
218 people viewed this question
Clive
Clive
Thomas F. Schneider
