Question about IBM ThinkPad R51 Notebook
Ten key pad keys are turned on. How do i switch them off
Cannot log on because letters are unavailable
  • rgoetz Jan 07, 2009
    This ten key is across the letter keys, when i type an "o" i get a 6
  • Dan rogers
    Dan rogers May 11, 2010
    Have you tried to turn the num.lock off?
    Problem Solver:
  • 6 Answers
Solution#1: Accidentally pressing Sft+Numlock key combination will activate & inactivates ten key pad. (You'll see light enabled in padlock symbol with a number in it [i.e.beside ALL CAPS symbol on your lap monitor]).
Use: "ShiftKey+NumLock" (NumbLock Key: 2nd panel from Top right on keyboard)
Posted on Sep 12, 2009
    Master:
  • 413 Answers
That is normally caused by the number lock being on. Look for a light that has a padlock symbol with a number in it. Then look in the upper right hand corner of the keyboard and look for a key that says num. lock. Push that button and try typing again. The keyboard should now display the characters that are on the keys
Posted on Jan 07, 2009
E130se how to write in upercase letter
use the shift key and the letters you wish to type .
Jan 11, 2017 | Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
Ibm thinkpad 2374 manuals
Does it actually have a wireless network adapter? Check the network adapter settings. Does it show both LAN and wireless? If it does you may need to use one of the Function keys to launch the interface to turn on the wireless.
Aug 19, 2014 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
How do I cancel netflix???
Open Safari, go to netflix.com, sign into your account. On the drop down menu in the upper right, click on "My account". Click on cancel whichever service you no longer want to have.
Fairly certain you cannot cancel your service from any of the mobile Netflix apps.
Jun 02, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
I've a acer laptop model no 4820T. In this touchpad option not working but left and right button was working.... wats the problem n wat to do? tel me soon............."
Try the following: Using your FN key and the F7 Key together it might work again. You could have toggled the touchpad off. If that does not work you have issues with either the touchpad or the operating system. Best of Luck.
Sep 14, 2013 | Computers & Internet
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
IBM ThinkPad R51 Notebook Logo
1,630 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
