Question about Dryers
Heats but dont dry after several attempts and load sizes and more
Had dryer 4 months didnt use 2 of them will not finish drying them.It has to be on high heavy then tried on different size loads.and still damp after several attempts.now it has started making a small high pitch and humming soundit comes and goes sometimes.It just started the rest has always been......
Please Help
  • Dryers Master
  • 8,220 Answers
Loose blower wheel/Stopped up filter housing
Heats but dont dry after several attempts and load - 070a05e.jpgIf I was Karmac I could read your mind and get the model number, probably give a better answer.
Posted on Jan 07, 2009
Permanent press cycle keeps shutting down and doesn't finish.
Hello. I don't know what make/model dryer you have but the problem could be with load size and type of clothing. The sensor bars are usually located on the front of the lint screen housing(you have to put your head in the dryer and look back to see them--they are 2 metal strips, approx 1/2" apart and at least several inches long). The damp/wet clothing keeps shorting across the strips, telling the main board to keep the dryer running. If there isn't enough of a load, the dryer may think that the clothes are dry prematurely and count down too quickly. The sensor bar technology *is not* an exact science--it works best on large loads with like clothing. For smaller loads, use time dry and adjust the temp setting accordingly. I hope I helped you.
Aug 22, 2015 | Dryers
My dryer is taking way to much time to dry a basic load
The problem is either a blocked lint filter or a restricted vent system if the dryer heats up normally or a faulty cycling thermostat if the dryer heats up erratically. Check and make sure the lint filter is clear. You may need to have a contractor have the vent system checked and cleaned as it is necessary to clean them at least once year or every six months if 4 to 5 loads are done everyday. Restricted vent system impedes the airflow and therefore the disposing of the steam it carries. This consequently results in the longer drying time.
Replace the cycling thermostat if the dryer is heating up erratically or does not heat up sufficiently.
Aug 21, 2011 | Kenmore Dryers
Kenmore dryer 90 series, heats a little, but doesn't get hot and takes 3 to 4 1/2 hrs to dry a med. size load.
Check vent path from lint filter all the way to the exhaust vent to make sure it is clear. If the dryer has a wet/dry sensor it could be malfunctioning. Try a manual cycle to see if the problem occurs then.
Jul 18, 2009 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
