SOURCE: Step to how to replce cmos battery toshiba 1805-s254
Hi!
If you already found the cmos battery, then try to check its "rating" and size to accomodate inside the board. After that fix it as it should be.
SOURCE: cmos error on bootup
Carefull! The 1800 had a notoriously lousy MB/bios problem. While it still works, get yourself to Toshiba support and get the LATEST bios for the right version of your board, and get it IN ASAP...
Otherwise you might well end up with a brick..
SOURCE: need to change cmos battery for toshiba laptop 1805-s274
look on back of laptop you will see some panels under panels you will see two little wires connected to mother board that's the cmos battery unplug it and change it
SOURCE: Cmos / Bios password
IF IT COMES TO A SCREEN THAT SAYS "TOSHIBA" AND AT THR BOTOM LEFT SAYS ''F2-UTIITY , F12- BOOT MENU'' CLICK F2 IMIDITLY AND USING THE RIGHT CONTROL BUTTON SCROLL TO ''SECURTY'' AND CHANCE THE PASS WORS
SOURCE: Toshiba Satellite A100 755 battery CMOS
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
50
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
