Question about Frigidaire FAS155K1 Air Conditioner
Hums and freezes up????
Hi- Just the other day I noticed that the AC unit wasnt cooling. I shut it off and it continued to make a humming noise, although the fan did quit blowing. I removed the front air filter cover and saw that the cooling fins were completely frosted over. The only way to stop the humming sound was to unplug it. I let it sit a few days, unplugged. I plugged it back in and same thing...it hummed while the power was shut off. It did cool and blow properly until it once again frosted up the cooling fins. Any ideas would be greatly appreciated. Chris
  • Anonymous Nov 11, 2007
    I have the same problem but without the hum and the fan works. Any ideas?
    I have the same problem with the fins freezing but there is no hum and the fan works. Any ideas?
    Scholar:
  • 125 Answers
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
Posted on May 29, 2007
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
Humming
You need to trace down that noise. Sounds like a bad or stuck relay or solenoid. Once you find what it is making the noise, you will either replace it, if it is bad, or find out why it is being energized continuously. Does this vehicle have a power rear door closer?
Nov 24, 2013 | 1994 Oldsmobile Bravada
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Sub zero. 650 reefer. Significant hum coming from top mounted compressor, but still marginal cooling. Now a louder hum and unit no longer cooling.
Hi roger,
I see you concern, and if the unit does not cool anymore and there is a humming noise then you will need to replace or have your compressor repaired no doubt.
Have a nice day,
mvincentc
Jul 03, 2011 | Kitchen Ranges
Unit is running, but is no longer cooling. Fan is blowing, but air is not chilled (or cold). Unit has been running fine until a couple days ago. It has been turned off for the last 12 hours and tried...
not sure if it is a package system or a split but this is what you do.go outside where your outdoor machine is, after it has been shut off for awhile, and you should hear 2 distinct noises.1 is the outdoor fan, you should see it spinning.the other is a comppressor hum.some compressors have noise bags on them so listen closely thru the fan noise.if you hear no hum listen for a hum about every 2 to 5 minutes.if you hear this hum every so often, chances are you compressor is seized or stuck.the only thing to do there is get a tech and try a big boost to get it going.
Aug 07, 2009 | Fedders A6P09S2A Air Conditioner
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Frigidaire FAS155K1 Air Conditioner Logo
633 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
