Question about Refrigerators
Thank you! I appreciate the response. I will try the hair dryer soon!
    Sniper:
  • 51 Answers
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 13, 2009
Hot tub blowing clip in 20 amp fuse on control board as soon as you fire up main pump, it will heat and circulate so i think problem is in pump but cant see anything obvious
Pump motor windings may be drawing too much current. Use ammeter to confirm.
If so, then the motor needs to be replaced. However, try running motor without pump for amperage - if the latter is binding, that could slow down the motor appreciably and be responsible for the high current draw.
Feb 13, 2017 | Dryers
How to fix decorative stitches for sewing machine.
Make & Model??? Sounds like the stitch selector mechanism is stuck. If it's a mechanical machine, you can try oiling the mechanics of the stitch selector with Tri-Flow Synthetic Oil and then heat with hand-held hair dryer.
Mar 23, 2015 | Sewing Machines
Blue sparks and burning smell while hair dryer is on
After 4 years of service it can be expected that your hair dryer will be needing replacement soon.
Jan 10, 2014 | Revlon 1875W Hair Dryer RV473
I had waist some water in it and it keep sayin reload software
It is water damaged and not worth repairing. Take out the battery. Try warming it with a hair dryer to dry it out. If that doesn't cure it dispose of it responsibly but keep the sim card.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Lands Phones
I spilled juice on my laptop and now it will not power on what do i need to do
just remove the laptop abttery as soon as possible and if you have hair dryer just use that to dry the water and connect the battery after 1 hour and see is there any luck. may be it is shrt inside just try this .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 27, 2010 | Computers & Internet
No dial on maytag dryer
heres what you do perm press is top right then delicates then airdry so start your dryer in the top right some where and when it stops mark it on face where it stoped and move it to start next cycle and repeat tell done
Feb 04, 2009 | Dryers
ROPER DRYER REX3615EWI
Hey billybob40s,
Does the dryer trip the circuit as soon as you push the start button or does it take a while to trip??
Oct 19, 2008 | Estate TEDX640JQ Electric Dryer
Help!
let me try and find a alternative download for it, I will get back to you as soon as i do
Aug 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
I have a fairly new Whirlpool dryer. It dries very well but when I take the clothes out the dryer has a lot of lint, hair, etc. in it. I just had someone clean my dryer vent and I still have the problem....
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Whirlpool Dryers
Connecting My Laptop to my T.V.
Try this test. Reduce the resolution on your laptop. Try 800x600. The boot screen is lower res than the desktop.
Nov 05, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
