Question about Sharp LC-19SK25U 19 in. LCD TV
My lc=19sk25u tv has low volume when set to stereo or mono
  • Anonymous Apr 22, 2009
    volume is not loud enough
  • 61 Answers
You may be able to "boost" the volume by setting it to a different equalizer setting...... Im unsure if your tv has it though i imagine it would.
EG: Rock, Vocal, Music etc
Posted on Jan 07, 2009
Stereo channels of Xenyx 1202 are very very quiet
It sounds as if the input is too low. what happens if you plug whatever is going into the stereo channels into a pair of mono channels. Or are you taking about the phono stereo tape input?
The stereo channels are line level whereas the other channels have both line and mic level inputs, what are you trying to put through the stereo channels? You must make sure the gain switch is set to the -10dB to get the most sensitivity (the mono channels have about -132dB max sensitivity BTW) You probably need a different mixer or possibly a submixer if you are needing more than 4 low level inputs.
May 06, 2014 | Behringer Music
Home theater hooked up volume sounds low
Check your different settings either in your t.v. or your amp. In your menu settings you can change your audio. Bass trebile etc. and even sometimes switching it from stereo,mono, dolby digital will increase your volume. Dolby digital is very quiet if your not running and exteranal amp system. so try changing it to stereo and your volume should increase.
Aug 31, 2009 | Panasonic Audio Players & Recorders
I have a Sharp lc 19SK25U that I need to know how to
Someone sent me the link to where I could print off a manuel for the Sharp Flat screen TV. I so very much appreciate everyones' help.
Thank you
Jun 23, 2009 | Sharp Televison & Video
Volume is too low
Hi, On this model, there is only one audio output, which is a mini jack (3.5mm). This jack is designed for use with headphones. Owners manuals for your tv can be downloaded at the Sharp website. Hopes this helps!
Feb 08, 2009 | Sharp LC-19SK25U 19 in. LCD TV
Mono sound only
I have an LC42D64U with firmware U0709111. This is an 11 month old unit. It was working fine until I lost power one day, then I couldn't get any sound. It always showed up as Audio: mono. I tried every setting and nothing (although XBOX via HDMI still played though the onboard audio, so I knew it wasn't a HW issue).
After searching around for a method to change the mono/stereo I resorted to the Fred Flintstone's fix and simply pulled the plug on it. Immediately after turning it back on it worked.
This is hardly a fix but it worked for me.
Nov 20, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Aug 07, 2008 | Sharp LC-42D64U 42 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SAP - I can't get my new TV out of Mono and into stereo.
Are you using a cable box sush as a Comcast cable box? If so then the volume control within the cable box is most likely not high enough for the TV to detect a stereo pilot signal. The Comcast remote (if thats what you have) still is programmed to operate the volume within thier box, the volume display will be at the top of the picture and it will be in white. Turn it up until the word "stereo" appears. then leave it at that setting and use your TV's volume control only.
Feb 13, 2007 | LG MU-42PM12X 42 in. HD-Ready Plasma...
Sharp LC-19SK25U 19 in. LCD TV Logo
162 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
