Probably the worst washing machine manual I have ever read!
Try this.
Put your wollens in the machine, set for cold water, Woollens Cycle and your 'Soak' detergent. It will agitate a bit, and as soon as it stops filling, turn it off.
After say 20 minutes. Then Move the dial to Spin, and pull the knob out. It _should_ pump out and spin.
as too the actuall program of this machine , I cant say for sure , but I can say the action you describe as (wrinse cycle) is supposed to do exactly as you described , Now "soak" is a different action entirely , this step it fills then holds for a time , then spins out . this is the action I like to use downy in seems to work better for me .
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
I had that problem at one time with my old washer and what it ended up
being was the Washer Dog Agitators were broken and causing the it to
slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
Let me know if there is anything else I can do.
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
