Question about Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range
Buzzer sounding continuously, error F3 or door pushing on off or opening and shutting door does not stop buzzer. Buzzer will stop but within minutes start again
exspert
  • 55 Answers
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
  • 5 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
Posted on Jan 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Posted on Sep 10, 2009
  • 3230 Answers
SOURCE: Washer starts cycle than flashes F 02 errer
Cause  -
F02 = Long Drain -- If the drain time exceeds 8 minutes, the water valves are turned off and "F02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Solution -
*Press PAUSE/CANCEL twice to clear the display. Check the drain hose and make sure it is not plugged or kinked.
 *Check the electrical connections at the pump and make sure the pump is running.
 *Check the drain pump filter for foreign objects.
 *If the above does not correct the problem, replace the pump.
Good Luck!!
Thanks
Posted on Sep 14, 2009
SOURCE: F1 appears on my machine within a few minutes when
I actually had the same problem and read some other blogs and found that this is a control board issue. Whirlpool actually had a recall on these boards and should cover the part and labor to fix. I called them today at 1-800-253-1301 and they are coming out to fix my washer this week. When you call they just need the model number and the serial number. Both can be found just inside the lid on your washer. Good luck!
Posted on Dec 07, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
The open door beeper constantly going off
I went to find the schematic for your unit to find out what type of sensor is in it. Your manual says it has a temperature warning alert. This is what I found.
.A. Whenever "PCB Control Panel" button\'s pushed, the buzzer rings.
B. After 2 minutes power\'s on, the buzzer rings 3 times.
C. Time of Buzzer: Forced Defrost Mode (3 times), Short Circuit Test (1 time)
D. When door opens, the buzzer rings every 1 minute for 5 minutes.
Be patient here now. Hopefully we will cure this. Allow me to say first that if this were MY fridge I would rope it like a calf, tie it to my truck, and gas it!
Okay, so with further reading it appears this fancy gizmo is supposed to warn of temperature changes due to low freon, door being open and temp drop and so on so basically it could be caused by something you are unaware of or it could be errors.
To make this answer short I am going to post the link to the manual.
http://www.fridge-manual.com/manuals/daewoo/Daewoo_RF-420.pdf
I graduated with an associates degree in electronics engineering this past summer and I cringed when I saw your manual so I will try to simplify what you see in that manual and say, unscrew the cap off the top hinge and unplug what you see. That will not harm your fridge and should make it shut up. Page 21 in the link.
Now in case your fridge light has been wired with that buzzer, which is probable since your device was made overseas you may leave it plugged in and check that the door switch isn\'t sticky. Put a flathead screwdriver to it and gently pry it upwards and it should pop out. Once you have it out push it in and out. It should spring freely. It IS possible whoever assembled it never put it in its slot snugly so the door is not touching it as it should. Prying it out and putting it back in may solve this. If the switch does not bounce freely when pushed it should be replaced. The switch can be unplugged to replace it if necessary.
My heart goes out to you. The manual is tough enough for the average non mechanical engineer but is lacking in basic English. Good luck.
Jan 05, 2014 | Daewoo Refrigerators
Door alarm buzzer goes off inadvertantly
in the door jam you should find the button for the buzzer some of these are adjustable the button might not be getting push in all the way if this doesnt fix the problem I would find that stupid buzzer and rip it out
Jan 25, 2013 | 1998 Ford Windstar
Buzzer sounds at random in 2004 Focus
LOL... the rear hatch needs to be realigned.. try moving the latch catch back a bit so it seals correctly!
Jul 30, 2012 | Ford Focus Cars & Trucks
Buzzer won't shut off. only when door is left open
could be a number of things, but you may want to test with an ohmmeter if you have one.
It sounds like your timer needs to be replaced. If the buzzer is not shutting off, the timer may not be turning to the off position. It may be really slow our out of wack, not letting the dryer completely dry. It also could be an error with the dryer's control module (kind of like a computer for the dryer)
I also recommend playing around with door switch, it to may be faulty. If the dryer does work with door closed, it is unlikely to be the door switch. You will have to test timer and door switch with ohmmeter or voltmeter to determine that the voltage current is constant and not speratic or shorting out.
May 18, 2009 | Kenmore Dryers
Done buzzer sounds
The cheapest solution is to continue leaving the door open. The timer is bad and hanging up at that particular point. They are typically 80 to 150 dollars to replace.
Mar 13, 2009 | Dryers
Kenmoore 70 series Buzzer will not stop
buzzer is built -in the timer you all should replace it if you really want it solved they have done their work over the years. It's not something you can just go in and unplug or cut sorry. Good Luck. Post your make and model numbers next time please.
Dec 19, 2008 | Kenmore 60172 Electric Commercial Dryer
Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
