Question about ASUS P4S8X-X Motherboard
Can not save current bois version: P4S8X-X BOOT BLOCK
When trying to save the file as a:\P4S8X-X boot block I'm getting a error message "General failure to writing disk A'' need to update bois to the correct version
I sent my system with intel desktop mother board and IntelPentium 4 processor to a service center for repairng. it cannot take key board and dont step into bios. but the service centre damaged my board and processor now. so how can iknow the prcessor original?
Posted on Jan 09, 2009
Computer starts but doesn't beep, and comes up with a message saying book block compatible version ver 0.16
Check this site and read on how to fix boot block. It sounds like there is a problem with your bios and it needs repair or recovery.
http://www.ehow.com/how_2185633_fix-boot-block.html
Nov 16, 2012 | Computers & Internet
ASUS Rampage GENE II
first download the ASUS EZ Flash software into a USB stick, after which you download the BIOS file there as well. Make sure to format the USB stick to be bootable first. Then boot the machine from USB first.
May 20, 2010 | ASUS P5PE-VM Motherboard
How do you fix boot problem? error message Starter Version 2.0 This machine has the following bootable system: >1: Version: SGOS 3.2.4.8, Release id: 22001 Monday December 13 2004...
You need to get a replacement disk for your appliance, I recommend contacting your Blue Coat partner/reseller or if you appliance is covered by a Blue Coat support/maintenance agreement go to www.bluecoat.com and contact support to RMA your appliance
Jan 28, 2010 | CacheFlow Blue Coat ProxySG 800 Model...
How do i get rid of the KERNEL_STACK_INPAGE_ERROR on my d600? Occasionally it says UNMOUNTABLE_BOOT_VOLUME instead. Help?
This issue can occur if a requested page of kernel data could not be read from the paging file into memory, or the master boot record is infected with a virus. To further determine the possible cause, you must properly interpret the error message. If both the first and third parameters are zero, then the four parameters are defined as:
  1. 0 (zero)
  2. Page Table Entry (PTE) value at time of error
  3. 0 (zero)
  4. Address of signature on kernel stack
If either the first or the third parameter is not a zero, then the following definitions apply:
  1. Status code
  2. I/O status code
  3. Page file number
  4. Offset into page file
If this is the case, the cause of this issue may be determined from the second parameter (the I/O status code) by using the following information that is listed in a "value of second parameter" followed by "general cause" format:
0xC000000E, or STATUS_NO_SUCH_DEVICE: the drive went unavailable, possibly a bad hard drive, disk array, and/or controller card.
0xC000009A, or STATUS_INSUFFICIENT_RESOURCES: lack of nonpaged pool resources.
0xC000009C, or STATUS_DEVICE_DATA_ERROR: bad blocks on the hard disk.
0xC000009D, or STATUS_DEVICE_NOT_CONNECTED: bad cabling, non-termination, or the controller is not able to obtain access to the hard disk.
0xC000016A, or STATUS_DISK_OPERATION_FAILED: bad blocks on the hard disk.
0xC0000185, or STATUS_IO_DEVICE_ERROR: improper termination or defective cabling of SCSI-based devices, or two devices attempting to use the same IRQ.
To resolve this issue, use the appropriate method:
Boot sector virus loadTOCNode(2, 'resolution'); To determine if you have a boot sector virus, run a current virus-checking program, and if needed, disinfect your computer.
Not a boot sector virus loadTOCNode(2, 'resolution'); View the System Log in Event Viewer for additional error messages that help you determine the device that is causing the error.
Bad block. Stop 0x77 is caused by a bad block in a paging file, or a disk controller error, or in extremely rare cases it is caused when non-paged pool resources are unavailable.
If the first and second parameters are 0, then the stack signature was not found in the kernel stack. The cause of this issue is defective hardware. If the I/O status is C0000185 and the paging file is on a SCSI-based hard disk, you should verify the disk cabling and SCSI termination.
If the I/O status code is 0xC000009C or 0xC000016A, this normally indicates that the data could not be read from the disk due to a bad block.
If you can restart your computer after the error message, Autochk runs automatically and tries to map out the bad sector. If for some reason Autochk does not scan the hard disk for errors, manually start the disk scanner. If your computer is formatted with the NTFS file system, run Chkdsk /f /r on the system partition. You must restart your computer before the disk scan begins. If you cannot start your computer due to this issue, use the Command Console and run Chkdsk /r.
Defective or unreliable random access memory (RAM) is another common cause of this issue.
Verify that all the adapter cards in your computer are properly seated.
Ensure that all adapter card contacts are clean.
Disable system caching in the BIOS to see if this resolves the error.
If this does not resolve the issue, your computer mainboard may be damaged.
Oct 23, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
EasyNote R4250 - Unable to boot, even in safe mode...
This is quite a stumbling block, if you have corrupt boot files, the only other way to fix this without the recovery cd is if you know how to reprogram the system32 boot log, Lord knows I don't. You could contact Packard Bell and see if they still have a recovery cd for this pc there email is supportqb@packarbell.com GL hope this helps.
Jun 20, 2009 | Computers & Internet
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
How to set the boot sequence on the Sharp PC-9000
I'm not sure with the BOIS version of this model, but try pressing F12 key when it start loading most of the time you will get option to select boot device. if not goto COMS and change the 1st booting device to hard disk.
Dec 06, 2007 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
ASUS P4S8X-X Motherboard Logo
118 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
