Question about Acer PD525 Multimedia Projector
I need to reset the lamp timer on a Acer PD 525 projector that I replace bulb on.
Found reset in menu. the first time I turned it on after replacing bulb it would not let me reset, but after I turned it off then back on I was able to do it. Not sure if this was a fluke or not.
Posted on Jan 08, 2009
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
Cannot reset lamp timer as will not project. Replaced the lamp in my 3m X50, bulb came right on. I had to shut it down before reseting the lamp timer. Now will not light up so that I can navigate the...
It does not sound like resetting the lamp timer is what is keeping the projector from throwing an image. Try walking through the steps of the installation backwards to remove the bulb completely. Then reinstall the bulb again from scratch making sure everything is seated properly. If it powers up again just remember to set the clock back on the bulb.
Mar 03, 2011 | 3M X50 Multimedia Projector
Our projector indicates that the light bulb needs to be replaced after replacing the light bulb once it still indicates that it needs to be replaced.
This is the excerpt from the manual on how to reset the lamp life timer.
Turn on the projector and use "Lamp Reset" after the lamp module is replaced.
Lamp Reset: (i) Press "Menu" ?§ (ii) Select "Options" ?§ (iii) Select "Lamp settings" ?§ (iv) Select "Lamp Reset ?§ (v) Select "Yes".
Jan 12, 2011 | Optoma HD65 DLP Projector
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Bulb replacement
u have to reset the lamp timer.
There is an menu entry to do that.
Sep 25, 2007 | Acer PD100 Multimedia Projector
Acer PD525 Multimedia Projector Logo
510 people viewed this question
Top Acer Office Equipment & Supplies Experts
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
