Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Manual for Craftsman Snower blower
Model #95052320-3,,,,,,,we are having lots of trouble removing the wheel off the axle......any suggestions??
4 Suggested Answers
  • 37 Answers
SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
Posted on Nov 23, 2008
  • 3 Answers
SOURCE: i have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Posted on Feb 22, 2009
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
Remove impel assy.
Hi Shirleu,
Here is the Craftsman's Manual for your model to fer too. The link is Craftsman 536 886190 26 Inch Snow Blower Owners Manual .
I am going to put you towards a video. By which. You will find a multitude of sears opportunities to view for your understanding at this link. These days . We all like to watch and see be fore we do.
Follow. Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
There is so much other content to choose from on the side bars; I even became levitating.
Fare. Well.
Dec 12, 2014 | Garden
Snowblower won't go into gear after replacing wheels
Do you still have the original wheels? You should be able to see some mechanism through which the axle was "keyed" to the wheels so when the axle turns, the wheels turn with it. The new wheels don't appear to have such a mechanism. Take one new wheel off and compare it carefully to one of the old wheels. You should be able to spot the difference.
Mar 01, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Replace friction wheel in a snowthrower
it looks to me the only special tool needed would be
spring ring pliers.
just removing nuts or blots on the left side and spring clips on both slide axle out pull wheel over bearing then reverse put together
Feb 03, 2014 | Garden
I have a mtd snower blower the engine and auger work buk the wheels stop turning
The most common cause of this is the drive belt is worn or broken. Sometimes the drive cable stretches (from the handle to the trans)
To check the belts and tension you remove the cover (usually plastic) in the middle of the snow thrower to look at the belts. Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side) The model number looks like 247.123456.
The belt closest to the engine drives the transmission. With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for your Craftsman and most MTD made models through searspartsdirect.com or jackssmallengines.com.
If you are unfamiliar with repairing machines you can get your MTD snow blower repaired by taking it to your local Sears. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
Looking for a front axle for a craftman 19.5 briggs and stratton 42" deck green color model do not have the model # also does anyone know if the wheels come off the axle or is it one unit
The wheels usually have a rubber cover in the center, remove that and there is an e-clip that can be removed with a flat blade screw driver, or pliers. The axle beam, spindles and wheels can all be serviced separately.
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
We are trying to remove the wheels and tines from the craftsman roto tiller in order to replace a broken drive chain. We are having a very difficult time getting the wheels and tines off. Any suggestions?
there should be a cotter pin or pin holding a large washer once you have removed these then you have to get the wheel to slide off the axle it has a keyway on it.i have taken a hammer and hit one side of the tire on the backside then turn the tire half way round and hit the tire from the backside and walk the wheel off the axle.if the axle is rusty shoot wd-40 around the axle and wheel .the wheel should slide back on as you line up the keyway when putting them back on.if your going after the chain the tines will have to come off too and the chain box split
May 28, 2010 | Craftsman 8.50 Torque Rating Dual...
May 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Jan 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Jan 16, 2009 | Craftsman Saws
Can not remove axle cover,
Nov 22, 2008 | Craftsman Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
65 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
