Question about Acer Aspire 9300 Notebook
New LCD Screen not working
I have replaced broken LCD screen on Acer travelmate 2310 laptop. On powering up laptop the screen lights up but is blank.Computer works normally when attached to another monitior. Any ideas please?
  • 4,234 Answers
The cable that connects the panel to the conputer is not in the connector correctly. It is probably skewed slightly rather than ebing straight into the connector. Since the individual connections are very close to each other, there are a few that are shorted or not connected at all.
Reseat the cables at both ends.
Dan
Posted on Jan 07, 2009
Laptop black out
When the following situations, you need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
Aug 08, 2013 | Acer Computers & Internet
Acer travelmate 4010. LCD screen has a row of bad segments running top to bottom. Besides replacing the screen, is there anything else I can do? Unplug and reboot etc...
When it comes to fixing PC'S ...what you want to do is change parts that don't work properly...and if you're do it yourself-er then you must know that changing the parts and doing yourself is where you save money...I'm sure that the most you would have to pay for a new screen is probably $100 bucks......
Apr 05, 2011 | Acer TRAVELMATE 4010 COMPATIBLE LAPTOP LCD...
Travemate C110. I replaced the hinge which was broken. To do this I had to disconnect the screen. I reconnected but I don't have any light on the screen. I can see the faint outline of the Windows...
Either the inverter board is dead (cheap to replace) or the backlight built in to the lcd is dead. The inverter board is inside the plastic bezel (frame) of the lcd panel. It is located at the bottom centre. Take the display apart and disconnect and reconnect the 2 inverter board connectors. It's the only circuit board inside the lcd panel, so you can't miss it. If this doesn't work, maybe try a new inverter board from acer (if still in stock) or connect the laptop to an external monitor and use it as a stationary pc.
Regards,
Joe
May 18, 2010 | Acer TravelMate 2300 Notebook
Blank screen on my acer laptop, it boots up, and i have put it on an external monitor, and it brings the screen up on the laptop,also tried changing the screen from 1 to 2 so the lcd is not broken, tried...
If an external monitor works fine then maybe you're having issues with the LCD's backlight. It happened to my laptop and I had to replace the whole LCD itself.
May 11, 2010 | Acer TravelMate 7120T (91.42A01.605) PC...
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
Acer TravelMate 230LC PC Notebook, lcd screen does nothing just black the power light comes on thats it what could it be
Shine a flashlight at the screen, if you can faintly see the image then your backlight has failed and you will have to contact acer to have it replaced.
Oct 04, 2009 | Acer TravelMate 2300 Notebook
Acer Travelmate 4p20 Display problem
Try to reset LCD video connector, if you have already changed and tried inverter, then check lamp.
Best of luck.
Regards;
Hassan
Sep 03, 2009 | Acer TravelMate 4220AWLMi Notebook
Acer travelmate 2410 broken screen
Hi
2 THINGS,one it could be the lcd cable has come loose behind the lid,
or the inverter is faulty.if your happy to take lid off an reseat the cable.
two.the screen cable maybe loose at the motherboard end.unplug power supply,remove battery,and unscrew keyboard,pull off cable an reseat the lcd cable.
i hope this may help
May 19, 2009 | Acer TravelMate 2300 Notebook
Ext screen with acer travelmate 2310
u most set the right resolution ans stuff under desktop under right mouse click choose properties and then settings there is possible to change the resolution
Apr 09, 2009 | Acer TravelMate 2300 Notebook
Acer laptop with broken screen recovery
press F8 key if u get try to enter in last known godd... also in safe mode change resolution settings to 800*600 or 1024*768.
Sep 29, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 9300 Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
