Question about Acer PD525 Multimedia Projector
Reset lamp timer on Acer PD525
I just picked this projector up (Acer PD525) with a dead bulb and have installed a new one. I can not find or figure out how to reset timer to zero. Any help would be greatly appreciated
  • gadgetman597 Jan 07, 2009
    Projector has been unpluged for over 2 weeks
  • Acer Master
  • 19,396 Answers
Check page 24 on the manual here: pj506d-manual.pdf
Posted on Jan 07, 2009
  • Ginko
    Ginko Jan 07, 2009
    "turn off your projecter for a long time; it helps u to reset the valuse to 0"
    That is false information and had been reported.
    Do a factory reset:
    Go to Advanced menu and do the following.
    "Press “Menu” to enter i ts menu. Use  /  to choose “ ” and press “Menu” to return
    the display parameters on all menus to the factory default settings."
  • Ginko
    Ginko Jan 07, 2009
    Check page 24 (29 on PDF ) on the manual and do factory reset from advanced menu, the expert posting the unplug fix posted incorrect information, there is a cmos battery on this unit, and you cannot reset unplugging power.
    Here is the manual. pj506d-manual.pdf
    Do not forget to rate the solution, as the problem had been hijacked by the other bad solution.
    Thanks.
  • 679 Answers
Turn off your projecter for a long time; it helps u to reset the valuse to 0
HOW RESET THE TIME OF LIFE HRS TO THE LAMP INSHARP ANC55LP PROJRCTOR
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 08, 2013 | Sharp ANC55LP Projector Replacement Lamp
Cannot reset lamp timer as will not project. Replaced the lamp in my 3m X50, bulb came right on. I had to shut it down before reseting the lamp timer. Now will not light up so that I can navigate the...
It does not sound like resetting the lamp timer is what is keeping the projector from throwing an image. Try walking through the steps of the installation backwards to remove the bulb completely. Then reinstall the bulb again from scratch making sure everything is seated properly. If it powers up again just remember to set the clock back on the bulb.
Mar 03, 2011 | 3M X50 Multimedia Projector
How do i reset my lamp timer on LG RD-JT30 Multimedia Projector, i have hust installed a new lamp but i do not have the remote control Derek
unfortunately, lg won't tell anyone outside of their service center how to do this. they even recomend that you send it to them. it's their way of ensuring return business. sorry.
Dec 09, 2009 | LG RD-JT30 Multimedia Projector
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
Lamp and temp lights come on after power up and stay on. Lamp only has 330 hours on it.
OK, that explains it. The bulb you have installed in the projector might be the original bulb that came with the projecoter when it was new. Just becuase it states 334 hours does not mean it is new. In fact, you could have a original bulb with 3000 hrs and reset the hour timer on the projector, which means your 3000 hour bulb might have 3334 hours on it because the person who owned it before you, reset the hour timer.. Best bet, buy a new bulb and reset the hour meter and see what happens. If you have the same problem, then your ballest might needs to be replace which is rare...
May 30, 2009 | ViewSonic PJ400 Multimedia Projector
Need new bulb and what ever goes with it
here's a link to the manual...
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/PD525-_E
and here's a link to find you a lamp ;) the lamp/lamp holder is an integral unit with this projector (and most others...). There are plenty of folks that sell replacements...usually $200-$300 since the unit has been discontinued.
http://www.google.com/search?q=acer+pd525+lamp
for what it's worth, I have one at work and at home and both are workhorses...aside from lamp replacements every ~2,000-3,000 hours, they've both run very well.
good luck,
shep.
anisotropic.us
Mar 07, 2009 | Acer PD525 Multimedia Projector
I need to reset the lamp timer on a Acer PD 525 projector that I replace bulb on.
Found reset in menu. the first time I turned it on after replacing bulb it would not let me reset, but after I turned it off then back on I was able to do it. Not sure if this was a fluke or not.
Jan 07, 2009 | Acer PD525 Multimedia Projector
Acer PD525
Same thing happen to mine..Power supply went bad and these is not one to be found anywhere. Peace of JUNK
May 23, 2008 | Acer PD525 Multimedia Projector
Toshiba portege m600 cannot connect to projector ACER PD525
you can extend the display to the projector through desktop settings
Dec 07, 2007 | Acer PD525 Multimedia Projector
Bulb replacement
u have to reset the lamp timer.
There is an menu entry to do that.
Thomas
Sep 25, 2007 | Acer PD100 Multimedia Projector
Acer PD525 Multimedia Projector Logo
407 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
