Question about Refrigerators
Refrigerator is running but not cooling
My Whirlpool refrigerator's compressor ( ET1FTTXKQ00) is making a ticking sound, similar to the way a car's a/c compressor makes when it is low on coolant. The fan in the freezer is running, but blowing warm air and the cold water dispenser will only dispense warm water. I have vacuumed under and inside of the refrigerator in hopes that the compressor was simply blocked, but with no luck. The refrigerator's manufactured date is 10-01, please help.
    Scholar:
  • 58 Answers
You have a bad compressor relay. to check it you will need a voltage meter. Remove the rear cover and you will see the compressor remove the relay held on by a wire. If the relay sounds like a maraca replace it with part #8201769. If is donesn't sound like somethings broken inside it check for continuity on all 3 compressor terminals ( all terminals should read closed ) now this can go to ways if the terminals read good and the relay is good then the compressor is lock rotor and has to be replaced. Most cases it's the relay Good luck hope this helps
Posted on Jan 08, 2009
I bought a may tag fridge 2 years ago model mb1956kes every 15 minutes my frige makes a ticking sound the sound last for 10 second
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Maytag Refrigerators
Makes a noise and isn't cooling anymore. Sounds like it might be the compressor
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 18, 2011 | Whirlpool Refrigerators
Refrigerator is not cooling, but it sounds like a
If you do not have frost build up on the rear wall inside the freezer ( defrost problem ) , then the overload/relay , attached to the compressor is bad . This part , plugs onto the compressor which can easily be replaced . Pt # 8201786. Instructions come with the part .
Sep 13, 2009 | Whirlpool Refrigerators
Compact refrigerator stopped cooling. If you turn the thermostat on the light flickers and makes a clicking sound. If you turn the refrigerator off the light stays on. In the back you can hear it ticking...
The clicking sounds like the compressor is trying to start. If the condenser fan running? If it is then you need to check the relay of the compressor. It could be a bad compressor.
Jun 14, 2009 | Refrigerators
Runs but will not cool compressor sound is not the same as it was
If there is a clicking noise coming from the compressor, replace the start relay on the compressor. Make sure the compressor fan motor is running.
Jun 07, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Not cooling or making ice - fan and lights OK
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
iufgh
Jan 12, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Refrigerator not cooling although lights and sound are OK
heatman101
\ fbvb
Whirlpool 20.8 Top won't cool neither refrigerator nor freezer
that's about right, if the compressor is drawing more than 4 amperes, then it is no good.
A reminder also to check the condenser for dirt and debris that could have accumulated at the front, this is a major contributor to compressor failure. check also the fan near the compressor. it should be running at the same time the compressor runs.
that's nice to hear from whirlpool....
good luck tapperal,
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest
hi thanks for the question when you say it short cycles that's the compressor relay trying to start the compressor i would replace the relay & overload at the compressor thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
455 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
