Question about OKI C9600hdn Laser Printer
Fatal error 917 on an Oki C9600 printer. What does this mean and how can I resolve the problem. Many thanks James
    Scholar:
  • 78 Answers
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Posted on Jan 07, 2009
Nous avons un probleme sur riso canon IRC2100 UNE CHOC est produit lors d'un circuit electriques j'aimerai trouver des solutions
Posted on Apr 11, 2010
Me marco ese error 917, en una oki c9800 y fue por que el transfer bed que acababa de poner se rompio. espero te ayude esta respuesta.
saludos
Posted on Jul 08, 2009
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Oki c9600 fatal error 175 ?
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Dec 06, 2009 | OKI C9600n Led Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
OKI C9600hdn Laser Printer Logo
7,771 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
