Question about Reddy R155D Utility Heater
Blowing smoke immediately prior to auto-shut-off
Our heater works fine, except just before it goes into it's high temp auto shut off function, it starts billowing out white smoke.
Is this a problem with the auto shut off not turning off the fan and fuel supply?
it turns the fire off, but the fan and the fuel are still blowing ( hence, the white billowing smoke)
isn't there a multi switch that should shut all three off?
  • 92 Answers
Try a new CAD falme sensor, or high limit control, both very cheap.
Posted on Jan 22, 2009
My 2008 dodge ram temp gauge goes from normal to high ,check gauge lite comes on in a few minutes temp gauge goes back to normal but heater will only blow cold air I,ll shut heater off wait a few minutes...
Souds like it's way low on coolant. The heater will blow cold air when the cooling system is so low that there is no water (coolant) running through the heater core. Then the thermostat opens, it trys to be normal but the system is low so it gets too hot in just a few minutes. If its that low, there must be a leak somwhere.
Nov 05, 2013 | 2008 Dodge Ram Pickup 1500
The temp gauge on my 2008 ram 1500 jumps from normal temp to hot checked engine the temp is fine my heater them puts out cold air and I have no heat if I shut heater off and wait a few minutes temp gauge...
It probably low on coolant. The heater will blow cold when there is not enough water (coolant) to keep the heater core full. Check the radiator (not the overflow reservoir) when it's cool.
Nov 05, 2013 | 1996 Dodge Ram 1500 Club Cab
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
1989 int. cutlass supreme-2.8lt- heater not blowing any hot air, fan works fine,def.,mid level, upper, lower functions work just fine when buttons pushed. When I turn the temp. control down to 60 the...
Your closing in. There is a motor that will open the heater core venting to allow it to blow into the car. Get a heater core install picture from your auto parts dealer or car dealer for specs of where and how it is driven.
Apr 17, 2011 | 1989 Oldsmobile Cutlass Supreme
2001 Ford Expedition heater inop. Will not get hot, will blow warm if fan is on low. I have changed the thermostate, cleaned out both heater cores, twice. Checked Blender Door, it works, moves back and...
the problem is more than likly a vacuum leak. look under the hood on the emissions lable and find the vac line that goes to the HVAC system. if you se the leak there great otherwise unless you work in an auto shop like me what i have done is smoked a cig and blew in the line to find the leak. the smoke will escape where the leak is...
Nov 19, 2010 | 2001 Ford Expedition
My Miller furnace occasionally stops in mid
If the flame looks good prior to the room air blower starting but becomes unstable when the blower starts, you have a crack or hole in the heat exchanger. I strongly suggest your technician do a test on it to see.
Dec 04, 2009 | Heating & Cooling
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Reddy R155D Utility Heater Logo
200 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
