SOURCE: Time is slow, not accurate at TAG QUARTZ watch
Rarely but sometimes, even the jewelers batteries can be low on energy even when new.
Very unusual that an expensive watch does what you're saying.
Has the watch ever been dropped, OR does it have any noticeable scatches or scuff marks along the edges? use a magnifying glass to inspect it carefully.
if you find unusual marks or scratches, you may have been sold a bad watch too.
SOURCE: Bulova has mechanical day/date display near 3
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
SOURCE: New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
