Question about HP DeskJet F380 All-In-One Printer
Hp deskjet f380 paper jam
At the end of a print job the last sheet completes the printing but does not eject the paper causing a jam.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Paper jam
At the back of the printer... open the feeder door and slowly remove the jammed papers.... put it back and put some paper in the tray and press resume button... this will continue printing the remaining print jobs.
good luck... happy FIXYA...
Aug 20, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380
your paper jam sensor is strucked or dislodge.please open it and check or send it for service
Apr 10, 2008 | HP DeskJet F380 All-In-One Printer
Hp F380
Pl. HP Deskjet F380 Printer Drives (Full Drivers)
Feb 16, 2008 | HP DeskJet F380 All-In-One Printer
Hp diskjet f380 not printing
Hi , prnter does not respond within a few seconds , the printing jobs are backlog , it must be delete all or cancelled it , so that the printer can move on.
Dec 28, 2007 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 Paper Problem
http://www.nodevice.com/driver/company/Hewlett-Packard/page3.html
Oct 01, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
463 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
