Question about Roper RAS8445KQ Top Load Washer
Smoke Smell The machine started to smell like something is burning inside. I had a look around (and under) when the machine was off and on, but couldn't locate anything. Did anyone suffer from a similar problem? Thanks a lot.
  • woolywollf31
    woolywollf31 Jan 07, 2009
    The machine works just fine except this smell.
  • 686 Answers
Is it sitting on a carpeted floor? If so raise it up with 3/4 inch boards to prevent overheating. Other than tat there is no solution
Posted on Apr 03, 2009
Smoke come in out while spinning
Don't know what machine you have if it has a belt check it. Take belt off & see the motor turns freely also with the belt off see if you can turn the drum if one of them won't turn the belt will slip & cause burning smell. Small clothes getting under the agitator even sometimes in the pump can cause this , check under agitator & check the pump it may not turn if a sock or something gets in it & this can cause the belt to slip. If these seem ok put it in spin & watch the motor it could have a short & will smoke. Good luck
hope this helps.
Nov 22, 2017 | Washing Machines
Smell of burning rubber and smoke from drawer
Sounds like your drive belt is loose or worn out. You will probably need a new belt. Is it possible something got inside the machine and jammed the belt?
Dec 12, 2014 | Hoover Washing Machines
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Smoke and burning smell cadillac cts
Where was the smoke? Inside the car or outside. See if the dealer will cover it under warranty
Jan 24, 2014 | Cadillac Cars & Trucks
Usually plastic bags that has been whipped up into the engine bay or the underside of the car and has been fused to the exhaust.
Aug 30, 2017 | 1995 Nissan Maxima
Washer had just started and i started to smell something, and all of a sudden a noise came from the washer and then smoke came from machine really bad, the noise sounded like air escaping
Looks like something is short circuited & due to which there is burning smell coming out of the machine. Disconnect the machine immediately & inspect the insides of the machine. Locate the burnt motor or burnt wires. You heard the noise coming out of the motor. It could be dislocated brushes due to which the motor could not rotate & in turn it burnt your motor.
Sep 18, 2011 | Admiral Washing Machines
Burning smell and smoke
Sounds like the belt has burnt off. You can check this by tilting the machine back and looking under it. Sometimes the belt gets hard and just starts to slip, then it will smoke and burn off. If this is the case, Just replace the belt and this will fix it.
Feb 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
When you turn it the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Roper RAS8445KQ Top Load Washer Logo
147 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
