Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump Logo
Posted on Jan 07, 2009
Looking for specs
Model 4631-041 hydro motor, GPM, RPM, Torque
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1721
Points
You can get from BJ Hydraulics 269-623-6743
I want to know torque specs for hyundai accent g4eh engine main and bigend torques
torque hyundai accent Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Torque specifications for cylinder head 2000 hyundai accent Are you aware that ... cover gasket on my 1997 Hyundai Accent GLS (engine code G4EH, 1.3L).
Hyundai Alpha engine - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Hyundai_Alpha_engine
WikipediaG4EH in a 1999 Hyundai Accent L ... lb·ft (132 N·m) at 4000 rpm, although some websites quote the torque rating as being 97 lb·ft (132 N·m) at 2700 rpm. ... 1992 Hyundai S-Coup? LS specifications - Carfolio.com · 1992 Hyundai S-Coup? GT ...
[PDF]AERA Torque Specs
www.aera.org/uploads/4/3/7/7/43776611/aera-torquespecs.pdf
AERA Torque Specs. 500 Coventry Lane, Suite 180, Crystal Lake, IL 60014. Toll-free Technical Hotline: 1-888-324-2372 (1-88-TECH-AERA). 815-526-7600 fax ...
Torque Specifications - AutoZone
www.autozone.com/.../Hyundai.../Specifications/Torque-Speci...
AutoZoneTorque Specifications. Print. Specific to: Hyundai ... Specific to: Hyundai Accent2006. Hyundai Azera 2006. Hyundai Elantra 2006. Hyundai Sonata 2006.
Club Accent Qu?bec • Consulter le sujet - hyundai motor s
I need the axle nut torque specifications
117lb/ft @3500 rpms is the torque rating for the engine .
As you have not stated the vehicle make, model year it will be difficult to give torque wrench settings .
Google Make, Model, year CV Axel nut torque. The spec you cite, is not right, that is the troque of the engine at that speed!
What are the torque specs for a 2003 Chevrolet trailblazer thermostat housing?
The 2003 Chevrolet Vortec 5300 generated 285 horsepower at 5,200 rpm and 325 ft.-lbs. of torque at 4,000 rpm. --------------------------------------------------------------
VVDI VAG Vehicle Diagnostic
1helpful
..torque specs. rod bearings. f-350 2008 diesel 6.4
6.4L Power Stroke Diesel V-8 ... 350 hp @ 3,000 rpm. Torque. 365 lb-ft @ 3,750 rpm. 457 lb-ft @ 3,250 rpm ...
Installing a used engine in my boat
This is a random choice for your engine.
You would really need the model and probably the serial to get the correct specs.
The Perkins Model AD3.152 engine used in Massey Ferguson 135 tractors built between 1968 and 1975 had the following torque specs.
45 hp
1211 ft pounds of torque at 1300 RPM
Max RPM was 2000
1helpful
2answers
I need the Torque Specs for a Nissan Q-R 2.5 Engine?
Nissan QR 2.5 engine produces a torque of 180 ft·lbf (244 N·m) of torque at 4000 rpm .
2helpful
2answers
WE ARE USING DANFOSS HYDRO MOTOR MODEL NO :OMS160 ON OUR PLASTIC INJECTION MOULDING MACHINE , I WANT TO KNOW ,HOW DO WE RECOGNISE A WORN OUT HYDRO MOTOR ANY PARTICULAR TEST TO CHECK OUT THE MALFUNCTIONING
Limit the pressure supplied to the inlet of the motor, plug the return port. Place the case drain line into a bucket, or install a case drain line if not equiped and comparte the flow to the manufacturers specs. I don't know what they are off hand, but shouldn't be more than 1 gpm I wouldn't think. Another quick test is if you can turn the bare shaft easily with no resistance when both fluid ports are open, the geroller set has quite a bit of wear. This quick test doesn't work in some applications such as wheel motors as they are sometimes ordered as "free running" motors. They are the same motor, but with a looser fitting geroller set.
Please visit http://hansonhydraulics.blogspot.com for more information.
Top Danfoss Garden Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Danfoss Garden Expert? Answer questions, earn points and help others
