Question about Xerox Phaser 8400 Laser Printer
Paper jam related to Maintenance Kit
I removed the Maintenance Kit on my Xerox Phaser 8400 by mistake. When I replaced it, it does not feed the paper and jams behind the front cover. I have tried to replace the Maintenance Kit with a new one but continue to get the paper jam.
Any suggestions or solutions would be greatly appreciated.
  • Anonymous Jan 13, 2009
    paper jams
    President:
  • 2,072 Answers
I wonder if you got some of the silicon lubricant from the maintenance kit on the rollers.
Try taking some alcohol or a cleaner such as fantastic, 409 etc and throughly clean all the rollers in the paper tray and along that transport behind the door.
If it isn't getting out of the tray you may coincidently have a smoothe feed roller, if it is feedinf a couple of inches out of the tray and stopping in the lower rollers I suspect a slipping registration clutch. Removing the maintenance kit seems like an odd thing to start a jamming problem. As I said clean the rollers, I guess see if you happened to have gotten a chunk of ink in the paper path from the catch tray.
Is there any damage to the paper? And tears or dents in the page?
Let me know we can resolve the problem.
Posted on Jan 07, 2009
XEROX PHASER 8400 SAYS CLEANING SHEET NEEDED. THE MACHINE JAMS EVERY TIME WE TRY TO FEEED IT IN.
There is probably a tiny sheet of paper stuck inside the printer somewhere which is causing the jam. You basically have to find out where the previous jam was and check the rollers to see if they are clear.
If it is cuz the cleaning sheet is too stiff, then you may need to feed it from the manual feed tray.
Oct 13, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400: Our printer keeps jamming. Some of the ink is staying on the right edge of the drum and it seems as the paper goes through the printer it gets stuck on that ink. We use only Xerox ink...
There are no less than 5 places on this model where you might clear a paper jam. Is it possible you still have a small bit of paper stuck somewhere?
http://www.office.xerox.com/userdoc/P8400/8400_Web/videos/paper_jams.html
Dec 03, 2009 | Xerox Phaser 8400 Laser Printer
Ink not being removed from metal drum, causing jam
Normally indicates that the mintenance kit is drying out and not properly lubricating the drum.
Or non xerox ink sticks have been known to cause that.
Jul 14, 2009 | Xerox Phaser 8400N Thermal Printer
Ink is sticking to the drum of my 8400, how can it be cleaned, and not happen again? This is causing paper jams.
Pull the maintence kit and look in the hole. If your printhead maintenance pivot plate (that the maintenance kit hangs on) is white, it needs to be repalced. It's probably cracked and flexing, not lubricating the drum properly. At the same time, the DM camshaft should probably be replaced. The cams crack on the thin side and rotate on the shaft, causing the maintenance process to malfunction.
Jul 07, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Error code 07,010.43:99907
You manually rotated the aluminum drum? Since you did that, I would suspect you have the print head wiper blade stuck between the drum and print head. The code you are getting it caused by the print head not being able to move freely.
The jamming is probably due to a bad registration clutch. Common failure on that machine.
You can go to Xerox.com, there is under documentation and drivers a parts list for that machine. You can reference the wiper blade and get the clutch part number there.
Let me know what other information you may need. I will be glad to help you get it running again.
Jun 17, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400 w/ Maintenance Kit problem
Sorry for the delay in responding. I am sure you have a bad registration clutch. Let me know and I will forward you part numbers , phone numbers and directions. Easy to replace.
Jan 07, 2009 | Xerox Phaser 8400 Laser Printer
Maintanance kit replace
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8400
The 8400 has a known issue with the plastic that was used for the tilt mechanism on the oiling roller. If you look inside where the cartridge is removed you should see a crack that opens when pressure is applied. The high heat causes this unit to crack. You need that part. Or some good super glue. I have fixed 3 of my 8400's with this same issue.
Good Luck
Nov 27, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
270 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
