Question about Zanussi ZWD1270 Front Load Washer / Dryer
ZANUSSI ZWD162701 washing always comes out cold - WHY?
And I mean freezing cold
Is this normal?
With all my previous machines the wash came out warm
Does it only rinse in cold water? or is there something wrong with the heating element.
If it's rinsing in cold, can I set it to rinse in warm?
  • Zanussi Master
  • 3,463 Answers
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
When I take my clothes out after washing them they are quite warm?? The final rinse is a cold rinse. So how is it that my clothes are warm when I take them out? Is this normal? never used to do it?
Without knowing what your machine is, I can only guess. Perhaps your machine has clogged cold input, and it's using hot because that's all it can get?
Maybe it always uses a little hot, and the cold is clogged or just not opening... Does it seem to be taking longer to fill than it used to?
Jun 17, 2015 | Washing Machines
WASH MACHINE NOT WORKING RIGHT
E62 Overheating during washing --- Drain, end of cycle.
Try changing temperature or cold wash.
Click if helped pl.
Apr 24, 2013 | Zanussi Washing Machines
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Zanussi 1250 aqua cycle washing machine can it run on cold water only
If it has 2 inlets at the rear, then you need to connect the cold supply to the hot and cold inlets by means of a Y piece, available from most major retail stores like B&Q, or a plumbers merchants.
If only 1 water inlet, then simply connect to the inlet valve.
Aug 14, 2010 | Zanussi Washing Machines
No hot water in my washing machine
heater thermostat need replacing at worse you may need a new pcb .call an expert
Feb 11, 2010 | Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Zanussi ZWF 1432 washing machine
because theres more water it takes a lot longer to heat.
May 04, 2008 | Zanussi ZWF1430W Front Load Washer
ZANUSSI WASHING MACHINE
seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
Sep 29, 2007 | Washing Machines
Zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWD1270 Front Load Washer / Dryer Logo
262 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
