Whirlpool MH2155XP Microwave Oven Logo
Dennis Allen Posted on Nov 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The control display on my microwave is very dim. Is there any way to make it brighter?
The display has become increasingly dimmer over time.
William Miller
Level 3:
  • Whirlpool Master 9,179 Answers
  • Posted on Nov 17, 2012
William Miller
Whirlpool Master
Level 3:
Answers
9179
Questions
Helped
4479399
Points
21747
If you had mentioned your full model number, we could have looked whether the VFD is available as a separate part in case your model has a VFD display, or whether the whole control board would have to be replaced.
If your model has an LCD type display, it may be weak LEDs or other failing components in the display backlight circuit.
We regularly repair microwave displays for $39.95 nationwide.
It's pretty rare for a microwave to have a display brightness feature.
Let us know if we can help you further.
Bosch microwave oven dim display panel options to troubleshoot, model # HMC80151UC
There is a capacitor on the back board to the display. It needs replacing. They get dimmer and dimmer over the years
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
How to make clock light brighter oneletrolux micro
youll find over time the fluorescent type displays darken
this is caused by the capacitors on the controller board becoming dried out
you need to replace all the values 1uf - 330uf at least
1helpful
The time display numbers are very dim and I can hardly read them.
There are two main causes for this dimming:
1. Dust & other particle buildup on the front of the display glass and the rear of the display window. This can be cleaned.
Cleaning the display is easy, but you need to be careful so you don't break the glass.
First you would unplug the microwave or turn off its breaker.
Then see the video here that shows you how to remove your control panel assembly in less than 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the plastic frame.
Then carefully (since the display is made of glass) remove your circuit board.
Using a soft cloth (since paper towels can scratch) lightly dampened with non-ammonia cleaner (since ammonia can damage some polycarbonate plastics), gently wipe off the front of the glass.
Then gently wipe off the back side of the plastic display window in the plastic control panel frame.
Reassemble, reinstall, and power it up, and it should be brighter, sometimes a whole lot brighter!
If that does not brighten it up enough, then...
2. Your vacuum display tube is wearing out and either the VFD display tube or the whole control circuit board must be replaced, depending on your model number, which you didn't mention.
If you'll contact me with your model number, I can give you an estimate and free do it yourself info.
R-1751 display issue and the work light is on always
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Microwave display - digits have become dim / partialy missing
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
Full details and *critical* safety, disassembly, and troubleshooting info is at Web our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
