Question about Lexmark X4270 All-In-One InkJet Printer
My printer has jobs stuck in que. deleting them doesn't work, how can i print a document? thanks, deedee evans
    President:
  • 8,637 Answers
Sounds like one of the drivers in the printer program maybe goofed up.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
Nov 29, 2012 | HP LaserJet 4300 Printer
Dell V715w all-in-one print job stuck in que
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
Mar 25, 2010 | Dell 966 All-In-One InkJet Printer
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
I can't "delete" a document from the que
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side
window.
On the left side click stop the service and wait forthe process to
stop
Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue
then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler
folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them
depending apon how many print jobs you submitted. You will have to
resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Apr 10, 2009 | Lexmark International Z611 Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Printer won't connect to computer
In Order to delete the Doc stuck in Que............ Go to start click on Run if it is a Vista just type it in Start Search.......... Type Services.Msc and hit enter.......... On that list select Print Spooler right click on it and say stop................ Now click on Start again and type in Spool and hit enter............. Double click on the Printers folder there and select each and everything there land hit delete........ Now that should become empty close that window........... Right click on the Print Spooler and click on Start........... Now go to all Programmes go to Lexmark X***** Series Printer u have and click on Uninstall......... Restart the Computer.......... Download the drivers from the website and install the downloaded drivers it will work................ Thanks
Jan 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
1 document stuck in que
Hello u6rysl,
Turn the printer off.
Reboot your machine.
Go back into the print queue and remove the print job.
- Vincent
Nov 22, 2008 | Office Equipment & Supplies
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
