Question about GE Profile JTP56 Electric Double Oven
Ge oven door locked
I went to use my oven and found that the top oven is locked. I tried turning off circuit breaking, but nothing workds, any suggestions??
  • 32 Answers
You oven is locked because it is self-cleaning. Some how the handle got moved and it initiated. You may need to let the oven finish self-cleaning. Usually, it can take about an hour to complete the process. Afterward, the oven will beep when done and your oven can be opened. Good luck.
Posted on May 31, 2007
SOURCE:
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
Fan stuck on, door locked
Hello,"If actual over temperature condition occurred"
Look for welded relay contacts. If this happens,replace oven control (also called clock or ERC).
IF NO OVER TEMPERATURE condition occurred: Look for high resistance connection or any other cause of high resistance in the oven temperature sensor circuit.Check sensor, sensor harness and sensor harness connection at sensor and oven control .Replace sensor if found defective.Check door lock switches.
REMEMBER: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Thanks
Jun 01, 2010 | GE Profile JTP95 Electric Single Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Older oven stuck on Clean and door is locked.
does your oven have a lift up top if does. lift up burns and silver box open box and you can unlatch the lock. hope workds
Apr 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Nov 21, 2008 | Ovens
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
"Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Jan 20, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
497 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
