Question about JVC Cameras
Jvc dvx8 video camera head cleaning fault
Hi i have a jvc dvx8 video camera with a fault it says to clean the head but have done this and still displays the same m
esage
  • 4,234 Answers
The cleaning tapes that are available are often ineffective. The heads are cloggd up and need to be cleaned professionally. The only way to clean these now is top open up the unit. This should only be done by a service center as it is easy to cause more damage. Also at the same time, the alignment should be checked.
Dan
Posted on Jan 07, 2009
Where do I find a driver for JVC-DVX8 using win 10
Short answer - you probably won't. As this equipment came out well before Win10, it is unlikely in the extreme that any drivers have been or will be available for it.
Dec 18, 2016 | Video Cameras
SCRATCHY SOUND
This could be a fault with the built-in microphone.
One thing to try before condemning the camera is to plug in an external microphone and see if the noise disappears.
Good luck
Oct 19, 2007 | JVC GR D370US camcorder Mini DV
I have bad audio static when playing my mini dv tapes on two JVC MIni DC Video cameras model GR-D244U and GR-D370U,need help?
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
Sep 07, 2016 | JVC GR Video Cameras
I have a jvc gr-d347u camcorder. i haven't
This kind of symptom appears in camcorder when its video head got dirty/ clogged, put video head cleaning tape in camcorder and clean head as per instructions provided with cleaning tape.
You can buy video head cleaning tape from Radio Shake or any store.
Thanks.
Dec 14, 2009 | JVC GR-D347U Camcorder
On replay black horizontal line
Hi!
Probably the video head has to be cleaned - you should give it to a local camera service center. I don't recommend using the cleaning tapes.
Hope this helps!
Tom
Jul 29, 2009 | JVC GR-D73E Mini DV Digital Camcorder
Video heads clogged - don't get cleaned with cleaning cassette
This needs to be solved at the shop if your product is under warranty.
ESLE
If you are adept at opening gadgets do this
Get a bottle carbon tetra chloride
Dip an end of ear buds and clean the heads without touching any plastic parts. Carbon tetra choloride dissolves plastic. The head look like a small "_" on the cylinder. There will be 2 of them
Babdi
Apr 19, 2009 | JVC GY-DV5000U Mini DV Digital Camcorder
Hi, my JVC mini DV Video Camera has fussy lines through any recordings and says the head needs cleaning. I've tried using the miniDV head cleaner tapes - but to no avail. Have you any...
It could be video head dust or the tape guide were out of alignment or it had been magnetized
In any case you should bring to JVC service center or JVC itself to repair this problem. They must connect your CAM into computer to check up and realignment DO NOT use the tape cleaning it won't help you sometime it cause more trouble such broken video head
Cheers
Dec 18, 2008 | JVC Cameras
Jvc camera model gr-d270u
hi , if you have the rec. signal in the display that mean evry thing is going good exept the head needs leaning too ways to have it solved if you know about cleaning then take off the cassete cover by unscew the two screws then with a clean white piece of paper hold it in one hand over the head cylender and with the second hand rotate the cylender some turnes and re record and check if you don't want or know how to open and do it just use the head cleaning tape and buy one if u don't have and play it in the cam., so easy , please don't forget to rate ,thanx
May 07, 2007 | JVC GR-D270US Mini DV Digital Camcorder
Black Horizontal Lines on Screen
mostly this is the result of defective or dirty video head. simply clean the video head by using head cleaning cassette. If it solves the problem, well, but if the problem remains contact the vendor.
Aug 16, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Eo4 error
hi a malfunction of some kind has occurred in this case the camcorders functions become unusable. -eject the cassette once and re-insert it - it claers up yoy sould consult your nearst jvc dealer. good luck
Apr 07, 2006 | JVC GR-DX25 Mini DV Digital Camcorder
Cameras Logo
53 people viewed this question
Top JVC Cameras Experts
Parshiv Luthra
Michael Galve
Michael Galve
Are you a JVC Camera Expert? Answer questions, earn points and help others
