Question about Zanussi WJS1265W Front Load Washer/Dryer
Machine frozenas kept in outhouse. Have been defrosting it with a small heater. Now water in OK, but cycle not working. Now full of water, but wont drain away! Tried to empty filter, but appears stuck. Cleaned tray and recess - still no joy. Any ideas? Thanks.
  • Zanussi Master
  • 3,463 Answers
Probably drain outlet hose and water in pump frozen, you will have
to wait for the the ice to melt in the hose, but if you put some hot water in drum, that should melt any ice in pump.
PLz rate my solution.
Thanks
Posted on Jan 07, 2009
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
Bosch wfl2000 machine works on every cycle apart from spin, washes drains etc but wont spin. Cheched brushes and removed and had motor tested all ok, belt fine, any ideas- Controller!!
are you sure its heating the water as it will not complete the wash cycle if the heater has failed, hence not getting to the spin cycle. try testing heater or see if water is warm coming out or glass warms up
May 31, 2011 | Washing Machines
I have a top mount Kenmore refrigerator, model no. 106.60272990, serial no. EK2929089. It is about 10 years old and works fine except for one problem that has kept recurring every 2-3 months over the last...
hey barry I had the same problem and i recently broke down and called a repair service, the repair person installed a small aluminum piece he refered to as a heat probe, on the heater coil which is behind the back plate in the freezer, he claims this will solve the problem, evidently the water created in the defrost cycle freezes before it can get down the drain, thus the drain becomes blocked with ice, subsequent cycling of the heater for defrost causes more water and ice buildup and the water overflows through air ducts into the refridgerator, I would check at an appilance parts store for this part it cost $20, unfortunatley the total cost of the service call was $ 227, My gripe is this is an obvious flaw in design and should have beeen addressed by Kenmore, if you make a part to remedy a problem then its an admission of the problem! Good Luck!
May 27, 2011 | Kenmore Top Freezer Refrigerator
I have replaced a defrost heater #AH1993872 in my refrigerator Kenmore side by side, model # 363.50232000, S/N 04727723. I would like to check, wheather the defrost heater works properly. What is the...
The defrost time is about 30-45 minutes. This does not mean that the heater is turned on for the full defrost time. It turns on until the defrost thermostat senses the temperature is at 40 deg F then it cuts the power to the heater. Then after the defrost cycle time is over, the compressor is then powered to continue the cooling cycle.
To test, locate the defrost timer. It looks something like this,
slamfix_39.jpg It can either be found in the temperature control box in the refrigerator compartment, or located somewhere near the compressor. When you find it, look for a round cam on the side. Using a flat screwdriver, turn it until it clicks. With the fridge plugged in, the compressor should be off and the defrost heaters should be warming up. You should either hear the ice crackling and melting and see the water flow down the drain tube to the pan below the refrigerator. After about 45 minutes, the compressor should turn on. Hope this helps you.
Mar 08, 2011 | Kenmore Side by Side Refrigerator
There is water coming from under the refrig. The overfill water pan is full that is under the freezer. The ice maker is working and so is the water dispenser. The coils are really dusty could this cause...
The overflow pan is the water that is collected during the AUTO DEFROST and usually the water evaporates off before the next defrost cycle. so if there is overflow of water on the collection tank , then the thermostat must be kept a little lower to reduce more frosting.
Jan 18, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Will not defrost on its' own. how do I detemine what is wrong; system includes a timer, a limit switch and heater. Is there a way I can manually start the defrost cycle and verify the "heater" is working,...
Good day,
Yes you can. First with a small bladed screw driver, turn the shaft of the timer clockwise while the machine is running. Wait 35 minutes, if the timer turns the machine back on, it's O.K. If not, it's defective and needs replaced. If it checks O.K. then it has to be either the limit thermostat or the heater. 90% of the time it's the limit, however, check the heater first. Remove the wires, and using an ohm meter test the heater for continuety. It should read less than 35 ohms. If it checks infinity, it burned out and must be replaced. If O.K. then just change the limit thermostat. It's the only item left that could be causing the problem.
P.S. It is standard proceedure to replace the limit thermostat if the heater checks bad. Replace both at the same time. If the limit checks bad, replace it only.
Jack...
Jul 13, 2010 | Whirlpool ET8WTKXK Top Freezer...
Recently purchased Candy gov58f. Placed in outhouse/garage. Will not start and continue to run necessary to stand with machine and keep re starting 2 or 3 times until runs .contacted engineers they say...
I have had the same problem. I contacted Candy who had had over 2000 calls this week about this. Place a pan of boiling water (still in the pan) in the machine for half an hour and then it will work. Apparently it is frozen! Hope this works for you too x
May 17, 2010 | Dryers
F37 fault code on washine machine
the machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
Dec 19, 2009 | Bosch Washing Machines
Leaking water line
should have a small metel clamp there if not you can get a small clamp about any where and the fill tube being partialy frozen can be an issue the easiest way ive found to deal with this is to get a eureka 301 hand held enviro steamer its a little investment but there are about 1000 outher uses for it around the house and it wont hurt the fridge just let it heat stick the tip in the in the ice maker fill tube where the water line goes and pull the trigger till steam comes out the other end bingo does windows sinks stoves etc.thaws evaprators clears frozen drains seal door gaskets without melting them getting this master tech http://www.overstock.com/Home-Garden/Eureka-350-Hot-Shot-Enviro-Steamer/371207/product.html?fp=F&kid=4087&cid=52417
Feb 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Zanussi WJS1265W Front Load Washer/Dryer Logo
49 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
