Question about Magellan RoadMate 300 GPS Receiver
Broken power socket on Roadmate 360
The socket where I plug the power adapter into the GPS unit broke. Can it be repaired?
What you need to do is take to a electronic repair shop and have them weld new cables to where the socket goes and from there you can do you on plug. or aask them to do it for you, i did fix mine this way..... hope it was helpful.......
Posted on Jun 10, 2009
    Problem Solver:
Yes you have to change the dc jack in it.. It took me about an hour..
Posted on Apr 21, 2009
After recently purchasing my Magellan Roadmate 1400 GPS the cigarette lighter adapter cord no longer charges the unit. I am able to charge it from a regular AC wall socket but it will not start up in my...
look in the tip of the DC charger and see if the fuse has blown. This is usually the case.
Be warned! starting the car with the GPS plugged into DC can blow your SIIRF chip... no more satellites! and an expensive repair. be thankful it was the fuse this time
Jul 06, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Broken RoadMate 700
Here are a few tests you can do. Bear in mind if the unit has not been charged for some time and the internal battery is completely flat, you will need to leave the unit on charge for some time even to get a charge light from the LED. Leave it on charge for at least 2 hours. First, check the LED is lit when the cable is plugged in to the cigarette lighter socket and/or mains charger? If it is not, the fuse in the cigarette lighter adapter may be faulty or the charger may not be working. If the fthe LED is lit, then is power available at the end of the cable that connects to your unit? Use your DC voltmeter to check this. If no power is available here, then your cable/charger is faulty - obtain a new one. If there is power at the connector, then the unit may be faulty.
Jun 10, 2007 | Magellan RoadMate 700 GPS Receiver
GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Jun 08, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Power pin fell off inside of Magellan Roadmate 3000T
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Jan 05, 2008 | Magellan RoadMate 3000T GPS Receiver
Won't turn on
One of the wires in your power cord could be broken. If you have the a/c adapter, see if you can power up with that. If you know someone else with a working Magellan, you could borrow his cord to test your unit.
If not, check the car adapter with a continuity tester. Put one tester probe on one of the side springs of the car plug and the other probe on the outside metal of the GPS plug. If that shows continuity, place one tester probe on the end tip of the car plug and the other inside the the GPS plug.
If either of those do not show continuity, first take apart the auto side of the cord. Check the fuse and the wire to contact solder joints. If they seem okay, carefully cut back the molded plastic from the GPS end and examine the wire to solder joints. If any are broken, replace the cord or resolder the joints.
Nov 05, 2007 | Magellan RoadMate 700 GPS Receiver
MAGELLEN ROADMATE 700 NO POWER
Nov 02, 2007 | Magellan RoadMate 700 GPS Receiver
Roadmate 700
One of the wires in your power cord could be broken and contacting intermittently. If you have the a/c adapter, see if you can power up with that. If you know someone else with a working Magellan, you could borrow his cord to test your unit.
Oct 28, 2007 | Magellan RoadMate 700 GPS Receiver
Power adapter
Hi, You can get the power adapter pin replaced at an Electronic store. Radio Shack has it but it must be special ordered, have you tested the power cord? I think that you might be right about the power socket cause thats what most common problem of the ones that I repair.
Oct 18, 2007 | Magellan RoadMate 300 GPS Receiver
No power
Two possible solutions. One is that you buy a cradle in which you put the gps unit on it or just buy a new one. Usually if the pin is broken, it needs repair.
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan RoadMate 300 GPS Receiver Logo
156 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
