Question about Sigma 50mm f2.8 EX Macro 1:1 Lens for Minolta
Macro lens is "in zoom in position " and don't going back
Lens mark is : Sigma f2.8 ex macro 1:1 ( use with Sony alfa 350 )
    New Friend:
  • 117 Answers
What is the fault
Posted on Jan 01, 2010
Sigma 17-50 2.8 EX HSM lens is stuck and won't zoom. It takes pictures Ok and sometimes it even focuses in automatic. I can also take pictures without zooming. Can someone help on how to fix.
Hi.
Probably the problem come from a loose screw inside zoom cylinder. Normally it happens due to constant use or vibration.
The GMR sensor is very sensitive to magnetized tools an needs an accurate position to function properly.
If you don´t have experiencie with this electronic systems, it is better you to contact Sigma Service in Ronkonkoma, N.Y.
Oct 17, 2015 | Sigma Cameras
I have an 18 - 200 mm sigma lens. problems are: 1. its lock does not work. the lens slides down to lower zoom magnification one raised to a diagonal position. 2. when fully extended, the thrid tube...
Send it in for repair
Sigma Canada
www.sigmacanada.ca/
SIGMA ART 24-35MM F2 DG HSM LENS. Lens details >> · More photos with this lens >>. SIGMA 24-70MM F2.8 IF EX DG HSM. Lens details >> · More photos ...
Lenses ' Sigma Corporation of America
https://www.sigmaphoto.com/lenses
Browse Sigma lenses including over 45 camera lenses available for most major mounts including Sigma, Canon, Nikon, Sony, Pentax and Micro Four Thirds ...‎Wide Angle Lenses · ‎Telephoto Lenses · ‎View All Lenses ' Sigma ... · ‎Art Lenses
Jul 27, 2017 | Sigma AF 28-200 Lens
Sigma User Manual for 105mm f2.8 Macro
Well you can please follow the link below to get your manual -
http://www.dphotojournal.com/sigma-105mm-f28-ex-dg-macro-reviews-sample-photos/
(click on the manual tab and then click on - Download Sigma 105mm f/2.8 EX DG Macro User Manual (PDF – 67kb), thats it)
Good Luck!!
Thanks for using FixYa!!
Jul 27, 2010 | Sigma Telephoto 105mm f/2.8 EX Macro...
Using old Sigma AF lenses with new DSLR Canon EOS
Hi Is the 28-70 a DF type if so it will work on a canon DSLR but if its the older one with the scale ring is on the outside of the lens it will need a rechip but I think thay are no longer avabile the 70-300 if is a super it will work or need a rechip if its a older one with a macro switch held on the lens with 2 screws it to old to up grade
Dec 25, 2009 | Sigma 28-70mm f/2.8 EX DG for Canon EOS
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Cameras Logo
188 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
