Question about IBM Deskstar 22GXP (DJNA-372200) Hard Drive
IBM Deskstar Model IC35L040AVVN0-0
I aquired this Hard drive from someone and formated it twice to remove all data. Then I converted it to NTFS. Now the computer will not recognise the disc at all. This puzzles me considering that all the proceedures where done on the same computer. I know that I have done somthing wrong, but I have no idea what. Thanking you in advance for any assistance whether effectice of not. Lindburgh
  • Meg Lindburgh
    Meg Lindburgh Jun 02, 2007
    Yes I am XP SP2
    No it does not show in either Disk Manager or Bios
    Thank you for you suggestion though
    Initially I made it a Slave and used the connection from mu Zip drive.
    I seriously think that I can say goodbye to this drive.
Well, I guess your running windows XP ? If you open the disk manager, does it show up there ? When you reboot, does the Bios discover the drive ?
Posted on May 30, 2007
How do i fix my usb flash drive .. it keeps going raw when i try to convert from fat32 to ntfs
When you say try to convert, you mean reformat from fat32 to NTFS? Depending on the size you may not be able to write it as a NTFS. Also, if you have anything on it you want to save, you need a raw recovery tool Squidoo has a good one.
However, if it won't let you format to anything and keeps reverting to raw, most likley your drive is damaged beyond normal repair.
Dec 29, 2014 | SanDisk Electronics - Others
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
After I format my hardisk for several times and the file system still showing RAW. how to make it ntfs.
Install the drive on a working computer and access through disc management. that will allow you to initialize the drive and format it ntfs. Goto my computer right click select manage select drive management. This works on XP if you have other OS than search for disc management for your OS.
Aug 29, 2013 | Seagate Computers & Internet
Hard Drive RAW System
Run diagnostics on the drive it may be failing. If it's ok you can try to reformat it from Windows Disk Management.
Or if you need to recover data for remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 11, 2012 | FireLite (USBFLB80) Hard Drive
I formatted my hitachi x.1000, oso2484, while trying to convert it over to ntfs ----- kept getting error messages with dos convert, Now the computer will not recognize the drive at all. did I remove a
What you need to do is that, make a backup from the HARD DRIVE onto another drive or computer then you will have to format the Hard drive. You are getting those errors because the conversion might not have been completed successfully or anything like that.
This is how you can format it
Go to start, Right - click on "My Computer" go to "Manage"
Then go to Disk Management in the Right pane. Then select the drive that you want to format to NTFS.
Go right at the bottom, right-click on the desired drive and select format. Formatting a drive n this manner will ERASE ALL DATA from the drive. This is why it is very important to Do a Backup of all your data before you do anything. Format your drive with NTFS
Apr 06, 2012 | Hitachi Computers & Internet
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
If you are running your computer under ntfs should your external harddrive be formatted the same instead of fats32. If it does can I move my back up from the external hard drive and move it back after...
The external hard drive can remain formatted as FAT32. NTFS and FAT32 are the file systems used by the individual disk drives, and do not effect the data being read or written (i.e., you can transfer data between the two with no worries about compatibility). There ARE differences, however, and many would suggest using NTFS to avoid some limitations with FAT32. For example, FAT32 drives have problems with individual files over 4GB. Formatting in NTFS is definitely recommended for people storing large files like video and other media files.
Yes, you can move any data you have off of your external hard drive (to your system hard drive or another external you use temporarily), format your external hard drive with NTFS, and then transfer your backups and other data back to your newly formatted external drive.
You can also convert the drive to NTFS; but I recommend backing up the data first anyway in case of (rare) problem during conversion. Here is a link that has directions for both scenarios (scroll down for conversion info) for Windows XP. http://www.microsoft.com/windowsxp/using/setup/tips/advanced/ntfs.mspx
The process to convert is similar for Vista and 7; here are the instructions from MS: http://windows.microsoft.com/en-US/windows-vista/Convert-a-hard-disk-or-partition-to-NTFS-format
Feb 02, 2011 | Western Digital My Book Essential Edition...
IBM deskstar 120 GXP 40GB will only format to 22GB. Its an old drive setup in an external usb enclosure
sounds like you're trying to format with FAT 16 or 32 which limits the partition size.
Try formatting with NFS which has no limit on partition sizes
Oct 25, 2009 | IBM Deskstar 120GXP 40 GB Hard Drive
Missing hard drive on a Win 98 computer / datarecovery ?
The best you can do is buy a small cable (+/-€ 10) IDE-USB. This cable lets you connect your IDE drive on a pc using USB.
Jan 05, 2009 | IBM Deskstar 75GXP (DTLA-307020) 20.6 GB...
When I try to back up my computer files for Windows Vista using a Toshiba 320GB capacity portable external hard drive I receive the message that I need a ntfs drive. Can my external drive be converted to...
Yes, it can:
Before you begin, connect your external hard drive.
To format the drive with NTFS
1.
Log on to your computer as an administrator.
2.
Click on the Vista Orb right-click Computer, and then click Manage.
3.
Under Storage, click Disk Management.
4.
If the Initialize and Convert Disk Wizard appears, click Next. If the wizard does not appear, skip to step 8.
3e609ff.gif 5.
On the Select Disks to Initialize page, click Next.
84b8e54.gif 6.
On the Select Disks to Convert page, click Next.
330a86a.gif 7.
On the Completing the Initialize and Convert Disk Wizard page, click Finish.
a63fbd2.gif 8.
Right-click your external drive (which will probably be drive E or drive F), and then click Format.
f8f5f91.gif 9.
In the Format dialog box, type a name for your external hard drive, such as Backup Drive. Then, click OK.
7560a25.gif 10.
Click OK again.
0a517a9.gif Windows XP formats your external hard drive. Within a few minutes, your drive will be ready for you to use.
Jul 17, 2008 | Toshiba Computers & Internet
IBM Deskstar 22GXP (DJNA-372200) Hard Drive Logo
54 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
