Question about Video Game Consoles & Games
Xbox 360 live
I,m trying to connect tok x box live and it koeeps saying ip adress failed and to ring my isp i rang them and they said they can,t help me
    Problem Solver:
  • 9 Answers
If u ring microsoft support they can walk you trough it just tell them the crowd you rang cant help . united kingdom08005871102/ttyusers 08005871103/ireland1800509186/tty users 1800509197/orfrom a mobile 35312420758 i would greatley apreciate it if u could rate this solution
Posted on Jan 11, 2009
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Failed ip address
your ip address should be activated by your isp
and then manually put it in the smart phone
Mar 04, 2009 | Microsoft Xbox 360 Console
Xbox elite ip adress failure
From the question above I think you are saying that when you unplug your Ethernet cable from your Internet connection out of your E-BOX and try to use it in your laptop, it doesn't work. If this is correct, then it's probably that your ISP only allows for 1x active address to be used at any one time. To overcome the problem you'll need to also power recycle your Internet modem to clear out the MAC address of the X-BOX once you've unplugged it and before you make the laptop connection. You would have to do this each time you wanted to swap between the devices.
Alternatively, get yourself a Router to sit in between the Modem and end devices and then have an additional permanent cable / 2nd physical port to use.
Oct 25, 2008 | Microsoft Xbox 360 Elite Console
Xbox live failed
This site has good information relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
How to connect to xbox live wirelessly
Aug 19, 2008 | Microsoft Xbox 360 Console
CAN"T SIGN IN TO XBOX LIVE
You might not have been banned. Not being able to connect to the DNS or having it fail can be caused by a few things:
The DNS address serves couldn't be reached
The info on the DNS server couldn't be snagged from your ISP or the DHCP server
The DNS values in the dashboard are wrong.
I don't want to come off like I am insulting your intelligence, but check your internet connection to make sure you have the ability to connect. I'm sure it is all in proper order. So the next thing you need to do is check to see if you IP is set and passes all the tests. If it isn't then you can click the more link on the test page to follow the directions on how to fix it.
You may also want to check out if you are using a XBOX live compatible ISP. Click on Learn More to see if you are using the right ISP or to adjust your settings. You can also check out the connectivity wizard to find out if there are some other issues revolving around this.
Still running into problems!?!?!? try running the modem directly into your XBOX. This has helped me in a few time of need.
Here are some helpful links on what you can do when your DNS fails:
http://xbox360help.blogspot.com/2007/03/dns-failed-on-xbox-360-live-test.html
And a link to a forum discussion regarding failed DNS
http://forum.teamxbox.com/archive/index.php/t-411837.html
Mar 04, 2008 | Microsoft Xbox 360 Console
Ip adress
this is not a fault with the xbox 360 rather it is a problem you have with your internet connection or router. you'll have to check or possibly renew dhcp (the protocol that issues ip addresses on your router if you use one) or contact your isp about it.
Feb 10, 2008 | Microsoft Xbox 360 Console
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Wireless connection of xbox 360
you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Nov 25, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
