Refrigerators Logo
sid Edward Posted on Nov 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHIRLPOOL S20C side by side fridge freezer ,FRONT MODULE FLASHING ALSO WHEN YOU LEAVE IT ON AFTER FEW HOURS TRIPS THE MAIN FUSE BOX AND CUTS OF THE ELECTRICITY!!
Richard Roth
Level 3:
Top Expert:
  • Refrigerators Master 9,472 Answers
  • Posted on Nov 16, 2012
Richard Roth
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628904
Points
28464
What is the model number of the unit?
5 Related Answers
Anonymous
  • 462 Answers
  • Posted on Mar 18, 2009
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
A
Anonymous
  • Posted on Apr 01, 2008
SOURCE: lg multi air flow gr-349sqf
Could be a wire short,bad defrost heater, or comp. pulling too many amps which is between 2 and 6 or higher being bad. I would say the main problem is you purchased a LG fridge which is a poorly made fridge,sorry.
Anonymous
  • 242 Answers
  • Posted on Dec 30, 2008
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Anonymous
  • Posted on Apr 19, 2010
SOURCE: Whirlpool American Fridge Freezer Clicking noise
my whirlpool amerian side by side it has got warning sign on with a ! at it has stop frezzing
Testimonial: "Thanks very much for your help, really appreciate it "
Anonymous
  • 43501 Answers
  • Posted on Oct 31, 2010
SOURCE: whirlpool 6th sense side by side fridge/freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
Defy fridge freezer G91641N panel , lights, keep flashing
When the panel lights on your Defy fridge freezer are flashing, it usually indicates an error or a specific condition that needs attention. Here are a few steps you can try to troubleshoot the issue:
  1. Power Reset: Start by performing a power reset to see if it resolves the flashing lights issue. Turn off the fridge freezer at the main power supply or unplug it from the electrical outlet. Leave it unplugged for a few minutes, and then plug it back in or switch on the main power supply. Check if the lights continue to flash.
  2. Check Error Codes: Consult the user manual or documentation for your Defy fridge freezer to identify the meaning of the flashing lights or any error codes displayed on the panel. The manual will provide specific information on what each flashing light or error code signifies and any recommended actions to resolve the issue.
  3. Temperature Settings: Ensure that the temperature settings on the fridge and freezer compartments are set correctly. Incorrect temperature settings can sometimes trigger error codes or unusual behavior. Adjust the settings to the recommended levels and observe if the flashing lights persist.
  4. Contact Customer Support: If the flashing lights persist or you are unable to identify the issue using the manual, it's recommended to contact the Defy customer support or an authorized service center. They can provide further guidance and assistance in diagnosing and resolving the problem.
1helpful
Vent from Whirlpool freezer to fridge is blocked full of ice
If there is ice build up on the inside back wall of the freezer or fresh food section, then you have a defrost problem. One way to check this is to remove the food, unplug the refrigerator and leave the doors open for a few hours. This will manually defrost the fridge and freezer. Once it has defrosted plug the refrigerator back in, do not put your food back in yet, wait about two hours and see if the temperature is back to normal. Once defrosted the fridge will work fine for about a week, then it will need to be defrosted again. There are three components that control defrost, the defrost timer, the defrost thermostat, and the defrost heaters. Any one of these could be the problem.
Ice maker quit working
Brenda, try the following.
1. disconnect power from the wall.
2. open fridge and freezer doors and leave them open for at least 5-6 hours. salvage foods you can.
3. after a few hours you will see a puddle of water under the fridge.
4. clean the floor and the fridge and freezer of any collected water.
5. power up the fridge and set at recommended level say 4.
6. you will hear humming noise. Let the fridge and freezer cool.
7. dont overload food.
good luck
Have a whirlpool american fridge freezer - we defrosted it but now when we turn it on it trips the fuse box
try pluging it in else where if it still does it theres a dead short mabey in the compressor
Whirlpool side by side - freezer keeps shutting
Your thermostat is defective and require replacement to settle this problem.
2helpful
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
2answers
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
