Question about Kenmore Refrigerators
Refrigerator is barely cooling, but freezer woks fine.
We noticed the other day that the refrigerator was not cooling properly. It is staying only slightly cool, while the freezer section is working fine. This refrigerator is a top freezer type unit. This unit was purchased approximately 10 years ago.
Sounds like a defrost problem. First though, check your settings that they are in the correct spots where the owner's manual tells you they should be. IF that is not the issue, next, can you look in the area of the back wall of the fridge to see if the condensor coils are all iced over? You may need to remove the rear inside panel to see them. No hard, couple of screws and your there. This is most commonly caused from little people or our beloved spouse (never us!) leaving the fridge door open a smidge overnight or through the day. Another common problem is after the holidays when someone other than yourself tries to stuff the 50 pound turkey in a 20 spot leaving no room for the door to shut. As a result, the chilling function will go into hyperdrive to keep cooling and eventually ice over and become very inefficient at cooling in the fridge. Even the freezer is effected, but it is not as easy to notice. Here's what to do. Once you find the large area along the back wall of the fridge that contains the frozen over coils, you will want to unplug the fridge and get that ice out of there completely. Using hot water and a catch basin to catch the water you pour over the coils, continue this until the ice is all gone. Make sure your settings are back to normal settings as per owner's manual and plug in. Should be all better now.
Posted on Jan 08, 2009
3-year old mini freezer/refrigerator has stopped working.
Seems to be compressor not working kindly check your refrigerator thermostat setting or capacitor device worn out
Need to replace
Jul 12, 2016 | Frost Refrigerators
Freezer works fine but fridge side is barely cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Jenn-Air JCD2389G Side by Side...
I have inherited a Jenn-air model # jcb2389grs and I notice the refrigerator is not cooling properly. I do not notice any air circulating to the top shelf when the freezer door is closed, but when the...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 30, 2010 | Refrigerators
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
Refrigerator compartment not cooling properly.
Yes The circulating fan behind the rear freezer wall is waring out. The fan with labor and material cost is around $300.00.
Jul 11, 2009 | Refrigerators
Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
127 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
