Question about Alpine Car Audio & Video
Missing chm630 changer 97 grandvoyager have chm604 will it fit
Tryed conecting the chm604 via chya-1 head unit still wont reconise the cd changer why?? should see it
  • 10 Answers
SOURCE: connceting a pioneer cdx - p670 to avic x1 head unit
the changer is either incompatible or the changer wire has been intrnaly dammaged to much bending shorts them out as the wires are no more than alluminum foil enclosed in shrink wrap
Posted on Mar 27, 2008
  • 1175 Answers
SOURCE: Lost cable between changer and head unit for CDX-P25
Posted on Jan 12, 2009
  • 233 Answers
SOURCE: Sony MDX 65 6 disc changer installation
No, you have to have a Sony head unit or a Sony FM Modulator package with the uni-link connector on it.
Posted on Jan 14, 2009
SOURCE: Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Posted on Mar 23, 2009
SOURCE: cd multi changer
I understand that there is a 'clear' or 'reset' button on some cd changers that must be pressed after unit is connected in car. The instructions for my model said to use the tip of a pencil.
Posted on Aug 13, 2009
Trying to fit a jaguar cd changer in the boot of my 2002 S type. Power and fibre optics, connected power at unit it ejects but the car doesn't recognise,press CDC nothing happens.....HELP please
You need to get the head unit programmed through the OBD connection to accept the cd changer, the unit does not know the changer is fitted........a jaguar main dealer or an independent jaguar garage will be able to do this for you, about half to one hour labour charge.
Aug 13, 2016 | Car Audio & Video
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm...
there should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Apr 03, 2011 | JVC CH-X1500 12-Disc CD Changer
several companies have multi disc CD players that are in dash..
and others have the changer in a remote location ( trunk) and are controled by the head unit..
Which model head unit do you have? It could very well fit into the later catagory and support a remote located disk changer..
Sep 29, 2010 | Car Audio & Video
2000 jeep grand cherokee limited 10 disk cd changer says ''err''
The in-trunk units have a tendancy to go bad. you can take the cover plastic interior cover off to access the CD changer, un bolt the changer, and visualy inspect the two rollers for debris, or missing /broken gears that move the rollers to take the CD from the CD cartrage to the player. if that looks fine, chances are that the laser went bad (common in rear mount units) and you can order a new one from Jeep, or you can remove it and update the in-dash head to an aftermarket of your choice (& yes you steering wheel controls will still work). you could also fit a more modern MP3 unit where the Changer was.
Feb 20, 2010 | 2000 Jeep Grand Cherokee
I have a factory fitted 6cd changer in my vw will not eject
Try disconnecting the power lead from the back of the head unit, wait 60 seconds then reconnect it. This should reset the head unit
Dec 27, 2009 | Car Audio & Video
Rockford and fostgate
i dont think different brands ar compatible as such.
Dec 01, 2008 | Rockford Fosgate RFX-8030 CD Changer
Cd multi changer
My experience with the x type is that everything that is added must be introduced to the ecu/car before it will operate. If the same is to apply for the multichanger it would have to be carried out by somebody who has the correct equipment.
Oct 02, 2008 | 2002 Jaguar X-Type
Connceting a pioneer cdx - p670 to avic x1 head unit
Dec 28, 2007 | Pioneer GPS AVIC-X1 car radio
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
