Question about Sewing Machines
Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
After working fine, Stitch length adjuster mover from ''0'' to ''4'' Needle broke and every new needle brakes after third cycle of Hook.
Ne sece konac
Posted on Dec 20, 2009
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Dec 11, 2017 | Sewing Machines
How to replace a timing gear from a pfaff 463
did you slacken the screws completely there should be two off if the shaft wasn't hammered it should slide easily there is even flats on the shaft you can use a small puller too
Nov 22, 2017 | PfaFF Sewing Machines
Thread shred. Pfaff 463. Using 120/19 new needle. And Sunguard Anti-wick UVR bonded polyester thread for marine canvas. Why is my thread shredding?
From my past sewing experience (not an industrial machine), the thread will shred if the needle/thread/fabric are incompatible. Could be the canvas is too coarse and is wearing on the thread like sandpaper. Remember, the thread/needle will penetrate over 10 times before that section of thread actually forms a stitch, so that's a lot of friction going on. In regular sewing, a top-stitch needle has a larger scarf which acts to protect the thread, however, not sure that is a choice for your machine.
http://www.upholster.com/upholstery-forum/index.php?topic=11340.0;wap2
Is Pfaff 463 Suitable For Upholstery
Pfaff 463 Instruction Book
May 19, 2017 | PfaFF Sewing Machines
How do I adjust the timing on a Singer20U109?
You can't do that yourself, you have to take to a dealer for that.
Nov 22, 2014 | Singer 20U109 Straight Stitch and Zig Zag...
My brother cs 8072 stitch length not working.
Are the feed dogs fully up and clean?
With the unthreaded machine transport a piece of paper with the feed dogs?
Is there a presser foot pressure adjustment? -- if so, it may need tweaking.
Do you have a tangle of thread under the needle plate (= throat plate) or hook and bobbin case area?
Do you have the stitch length set to greater than 0?
Jun 26, 2014 | Brother CS-8072 Computerized Sewing...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Juki LZ 586 industrial zigzag
Most likely medium setting is best to set your machine for adjustment
Dec 06, 2013 | Sewing Machines
How do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Jul 30, 2012 | PfaFF Sewing Machines
Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Mar 14, 2009 | Sewing Machines
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Sewing Machines Logo
632 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
