Question about JVC XA-HD500 MP3 Player
Playlists disappearing I upgraded to media player 11 from media player 10. Now when I sync my mp3 player, some of the playlists don't show up on the mp3 player. Sometimes they are there and when I turn it off and turn it on again they disappear and I have to sync again. All the songs get downloaded but the playlists don't.
How to put songs in NW-S205F SONY ERICSSON WALKMAN
Windows media player works for all MP3 players, but don't confuse it with Media Center. Goto the sync tab and make a playlist for the player, hit sync, and viola music. Make sure the correct device is selected in the sync tab before you start.
Apr 17, 2012 | Sony Walkman Audio Players & Recorders
I cant put a playlist on my mp3
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 26, 2009 | Sony NWZ-E436F MP3 Player
RE:WINDOWS MEDIA PLAYER 11 IN VISTA
Does your player show up as being connected in WMP11
Sync mode ? If not, a firmware installation for the player is needed.
If yes, did you perform doing next actions ?
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 04, 2009 | SanDisk Sansa e250 MP3 Player
Syncing files from Media Player to Rca Th1100a
You can view your playlist by opening the device in windows explorer. Start/My Computer/double click corresponding drive letter to your device.
For a copy of the user guide .pdf e-mail a request to
facsman@gmail.com & I'll e-mail you a copy.
Feb 02, 2009 | RCA TH1101 MP3 Player
Menu
These directions only apply to the Philips SA6045/37:
It's not going to be easy, because you will have to do two undesirable things: 1) Set your player up for auto-sync, which will result in the player adding unwanted media files to your player without your consent - and possibly overloading your player; and 2) You will have to roll back to Windows Media Player 10.
If you ask me, it's not worth it, but here's the procedure:
  1. Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
  2. Hook up the Player to the computer, allow a few minutes for the Windows Media player to recognize and detect the connection of the Player.
  3. Click on the Sync tab.
  4. Click on “Sync settings” or “Set up sync”
  5. In the pop-up window, select the playlists that you want to sync
  6. Click “OK”, the sync will start automatically
Note: playlists never show up in the device panel under the sync tab of Windows media Player even if they are on your device. Check on your device whether you can see the playlist.
-Tha Mp3 Doctor
Sep 12, 2008 | Philips GoGear Flash MP3 Player
Sony NWZ-S616F playlist problem
to add files to walkman i open the walkman icon that appears when i connect to pc an find and open folder named songs....drag and drop your song files ( as mp3) and thats all
hope this helps
Sep 08, 2008 | Sony Walkman NWZ-S616F MP3 Player
Download music to my scandisk sansa e260
When you turn on the player, select the music menu, and then scroll down until the playlists logo appears - select that and then your playlist name should be there.
If it still isn't there, then the songs that you tried to sync have some sort of licensing restriction on them that does not allow them to be synced to a portable device - wmp will show them as synced, but alas - they will never actually show up on the player.
May 22, 2008 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE with my "sony walkman NWZ-B105F MP3 PLAYER."
make sure your downloading it to the right folder on the mp3 player its usualy the music folder or you can try and use windows media player here are some instructions for that option.
--**Windows Media Player**--
Apr 12, 2008 | Sony Walkman NWZ-B105F MP3 Player
No playlist found
One of the pesky features of windows Media Player is that if you delete the song/playlist from the computer's harddrive, and then resync your device to that same computer, then oftentimes the song/playlist disappears. Reacquire the song/playlist, and then try resyncing to the goGear again.
-Tha Mp3 Doctor
Dec 06, 2007 | Philips GoGear HDD1830 MP3 Player
IRiver H10 - Cannot update playlists
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Feb 20, 2007 | iRiver H10 MP3 Player
JVC XA-HD500 MP3 Player Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
