Question about Samsung Digimax A7 Digital Camera
Battery Low with NiMH (won't turn on) OK with Alkaline
Camera bought in '05 worked fine for about a year. Then it started giving low battery indication, followed by immediate turn-off, with freshly charged NiMH batteries. I learnt recently about the voltage difference between NiMH and alkaline, so I tried a pair of regular AA -- camera works fine! Would be interested to know if anybody else has experienced this problem, how hard and costly it may be to repair ?
    Genius:
  • 2,985 Answers
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
Posted on May 29, 2007
SOURCE:
Put in new batteries. It will turn on and then stay on for about 1 second and then goes black. Help. I have the kodak easy share c183
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to Ni-MH or alkaline batteries.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
May 23, 2014 | Cameras
Camera won't turn on with new batteries
Also make sure all contacts on batteries and in the camera are clean and shiny. Only use dry cloth or cotton swabs if you want to clean contacts.
May 20, 2014 | Discovery Kids 0.3-Megapixel Digital...
I just bought a Polaroid 300 and the low battery lights keep blinking, I've put 3 sets of new batteries in it and the lights still blink. Anything else I can do?
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
May 12, 2014 | Cameras
Medion 85914
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth, Or a cotton swap. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Mar 13, 2014 | Cameras
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Yashica com
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to NiMH or alkaline batteries.
Jan 03, 2014 | Cameras
Low battery on screen and shut off
These cameras need good batteries. Make sure you either are using quality Alkaline batteries or NiMH rechargeable.
Oct 30, 2013 | Casio Exilim EX-FH20 Digital Camera
I bought my canon S5IS 2 years ago.For these 2 years it worked fine but now it is showing "Low battery problem" even when the battery is full charged.I also bought new batteries but that also in...
Make sure that the battery terminals in your camera are clean (rub them with a pencil eraser, q-tip or micro fiber cloth). Dirty terminals can cause poor contact with your batteries, therefore, impacting there performance.
Also, if you are using rechargeable batteries, your batteries may simply need replaced. Try testing the camera with a new set of alkaline or NiMH batteries.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Brand New Canon Powershot A1000 IS battery power always low
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 22, 2009 | Canon Powershot A1000IS Digital Camera
Samsung Digimax A7 Digital Camera Logo
166 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
