Question about Kenmore 53262 / 53264 / 53269 Side by Side Refrigerator
Kenmore Side by side Model #53271... not cold
I thought someone left the freezer door open the other day and everything defrosted, got all the ice off the walls and cleaned the freezer, noticed the fridge side is not getting very cold at all...the freezer is making ice and seems to be fine except that there is frost build-up on the back wall again. Cleaned underneath the fridge as much as I could...please can someone help me figure this out or do I need to call for service?
  • cindy1916 Jan 07, 2009
    How do I attempt to check for all these problems?
    Genius:
  • 1,122 Answers
You have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Posted on Jan 07, 2009
  • MIKE major Jan 08, 2009
    you need a volt meter,one by one eliminate each part,the fan is the easyest,is it running? find the defrost timer and put it in defrost,remove freezer wall panel and see if the heater is melting the frost off,if not you have to use the meter on the heater element to see if it is bad,if it is bad replace it, if good move on to the bimetal switch,the round thing clipped on to the coils,if good then it's the defrost timer thats bad,if not replace,let me know how you do-mike
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
My kenmore refrigerator has no cold air
If the compressor is running and warm air is coming into the refrigerator compartment, you probably have a blown compressor or no freon. Neither is a DIY repair, you pretty much have to call a repair service.
If the compressor is not running, you could have a broken thermostat, which may or may not be readily user serviceable.
If this is a side-by-side or other split refrigerator/freezer, check that the freezer side isn't frosted up.
If the freezer is at least cool , the coils in back may be packed with ice, which prevents air movement. The simplest solution is to just unplug the unit for a day or so (sorry about your food) and let the ice melt.
Then you ought to try to figure out why it froze up. If someone left the door open, that is a sufficient cause, but if not, you may have a bad defrost timer. If you don't fix the root cause, it is going to freeze up again.
Oct 16, 2009 | Kenmore Refrigerators
Kenmore side by side fridge model #:596.58695890
The defrost heaters are bad. Take the inside back panel out. Take a hair dryer and defrost the back where you took the panel off. You will find a set of coils under the ice. Inside those coils there will be a heater. Either one made of the same thing oven elements are made of or they will be glass with a coil running through it. You can inspect them and most of the time you will be able to see either the glass broken or the coil inside the glass. Or if it's made out of what a ovens is made of you will see where it is burned into. After defrosting, you can put the panel back in and turn the fridge back on. It will work normaly for around three days before it starts frosting back up. This will save your food and give you enough time to either get the part to fix or have someone to come out to fix. Word of advice. If you have someone to fix it, be sure to defrost it at least 24hrs befroe they come because it's iced up they will have to defrost it and as you will see. It takes time and they will charge you by the hour to do it. Good luck
Please rate this solution. Thanks
Aug 19, 2009 | Kenmore Refrigerators
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
167 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
