Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fiher and Paykel dishwasher
Double draw dishwasher. Top draw will to start. Bottom draw works as normal.
  • Gary Davd
    Gary Davd May 11, 2010
    please re-discribe your problem better
    Sergeant:
  • 351 Answers
Check the lid switch if it beeps fast.
Posted on Mar 02, 2008
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
Dishwasher draw not emptying water at end of washing cycle
I am assuming you have a Fisher Paykel or similar double drawer dishwasher. Based on your symptoms it is very likely there is dirt or some blockage in the drain sump which needs to be cleared. If you have followed the normal procedure of cleaning filters etc, and there is no difference then you will have to take a thin rigid metal wire and run it through the channel between the rotor cavity and the drain sump. There could be a seed or a bone chip sitting there. I am assuming the pump rotor runs normal and you can hear water flow through the drain hose into outlet drain. Please provide make and model number of dishwasher for help with better diagnostic.
Aug 28, 2014 | Dishwashers
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
NO POWER TO TOP DRAW
Not sure which model you have but if top drawer in double drawer has no power then it could mean a few things - either the thermal cutoff sensor has blown or the power board at the base of the dishwasher (under bottom drawer has blown). If you are not getting an F2 error on bottom drawer then more likely it is the thermal sensor. Not an easy job to fix as the whole heater assembly has to be replaced. The cutoff is integrated with the heater. The power board is easy to replace provided you have good handyman skills. ALWAYS TAKE OUT MAINS CABLE before working inside the dishwasher.
Mar 20, 2013 | Fisher and Paykel Dishwashers
I have a 10 year old dishdraw (Model No DD601v2). It is displaying a fault message "F1" on the top draw display and will not start. What fault is this indicating?
Normally F1 should display in both drawers.
But this is a bit unsual. Please confirm if you are still able to operate the bottom drawer.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
NO POWER Fisher Paykel DD603 double drawer
Check to see float switch (located on the bottom of cabinet below bottom draw )hasnt moved or dislodged in transit.(Access by way of back panel-easiest) or removing bottom draw.
Sep 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel twin draw
I'm not really sure. With the double drawer configuration, I know the top drawer is larger than the bottom drawer. If I had to take a guess, I would say the single drawer might fit in the top of the double drawer.
Jun 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
153 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
