Question about Sony Playstation 3 (PS3) Console
Getting information off Ps3 hard drive
I have to exchange my Ps3 due to a recent problem, and was told i will lose any saved data, is there any way of transferring saved data such as an online profile (Call Of Duty) onto my new PlayStation?
  • 124 Answers
Your online profile is not on system itself stored in sony database just use a memory stick and it will save your game saves and any other media. when you get new system create a user and when you go to sign up for psnetwork use existing account info and your account will be there
Posted on Jan 07, 2009
How do i fix a corrupted HHD on my ps3 without deleting my information.
That's a tricky one. I make no guarantees, but check out the Playstation 3 Safe Mode.
I would start with option 2 (Restore Default Settings). Apparently this guarantees it will preserve your information and attempt to fix the PS3.
If it doesn't work, move on to option 3 (Restore File System). This one makes no guarantees; you might lose your information, but hey you might fix the problem and still have your info!
---Everything after this point wont' save your information---
Finally, there's options 4 (Rebuild Database) and 5 (Restore PS3 System). These delete everything, but you should be able to get your hard drive back to working condition.
But if for some reason it doesn't go back to working, you could just replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
Alternatively,
you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe). They won't save your information, but they will get your PS3 working again.
Just so you know, anything you purchased on the PSN store (DLC/games) can be re-downloaded for free. All your trophies are saved online too (assuming you synced it). You'll just lose local content (game saves/data, pictures, videos).
Hope you can salvage it; good luck!
Mar 22, 2011 | Sony Playstation 3 (PS3) Console
Tip
How to solve error code 8002F14E on a ps3 or playstation 3
This error code relates to an update error either the update didnt complete or it was a bad update.
If you have any warranty left on your ps3 then please dont mess about with it just take it back to where you brought it from and get it exchanged for a new one.
Below is a couple of ideas that people have used to solve this problem now the first solution i can advise you to do as it dont require you to remove any parts and does usually solve the problem, i have solved the problem that way a couple of times on peoples ps3 and it works say 8 out of 10 of the times so you can give that a try just goto the ps3 official website for your country and then you can download the updates and try a full update.
Now the second way does sometimes work but less often and messing with your hard drive means your going to lose anything saved on it and you may get errors after so i cant advise you on doing this at all as its not recomended to work but may work its all up to you at the end of the day.
try the new update first then get back to me with what happens before trying the second way ok,
Go to the UK PS3 official site and access the download PS3 updates page. Download the latest PS3 updates from this site onto a USB Memory Stick, saved in a Folder PS3\UPDATES (must be in capitals). Plug the memory stick into any of the USB ports on the PS3 and try to run the update again. I had to swith it off, and back on again numerous times still getting the same error but then for no reason it decided to complete the update and now everything is ok.
This is the second way but dont try this untill you have tried the first way several times the update may not take so you need to keep trying until it does take only do the next option as a last resort but it will format the hard drive meaning you lose everything saved on it and this isnt an advisable coarse of action.
-Open the side of your PS3 where your HDD is. Take the screw out, but leave the HDD in.
-Whenthe update begins, slide your HDD out of the slot. It will tell you an error occured and it tells you to restart your system and try again. Instead, let the count from 60 run out, your screen will go blank for aabout 30 seconds then it will start back up and tell you that your Hard Drive needs to be reformatted. Now, slide your HDD into place again, and continue with the format. You will lose all your saved data, but your console will work again.
If after trying them you still have no joy then you should contact sony and they should fix this for you for free as this isnt a fault you have caused yourself its a fault with with either their update or the ps3 hard drive so contact them and tell them your problem.
If you have any warranty left on your ps3 then take it back to where you brought it from and they will exchange it for a new one for you.
on Mar 16, 2010 | Video Game Consoles & Games
Ps3 keeps freezing on me.
This is usually caused by two major conditions.
The first condition being that if the Hard disk is really loaded with data and they are occupying a really large amount of the total disk space. This makes the console to have some kind of extra work to do while loading all the data which you have loaded onto it.
The second most known cause for this issue is as a result of errors in the hard disk or system. It makes it difficult for the system to operate as it should do normally.
Whatever the case may be, you can solve it by doing a hard reset on the PS3 console.
Below is the instruction on how to do a hard reset.
2220976.gif i.ad?site=techrecipes&adspace=ros&size=728x90&requestid=701187742 entertainment;kw=;ppos=atf;tile=1;sz=728x90;ord=123456789? leanandgreen;sz=1x1;ord=123456789? 2220796.gif i.ad?site=techrecipes&adspace=ros&size=160x600&requestid=114756662 entertainment;kw=;ppos=btf;tile=3;sz=120x600,160x600;ord=123456789? PS3 - How to do a factory / hard reset user-icon.jpg Contributed by seamonkey420 date-icon.jpg April 9, 2007
tag-icon.jpg Tagged: Games
entertainment;kw=;ppos=atf;tile=2;sz=728x90;ord=123456789? Well, i had some major problems w/my PS3 recently locking up and not playing any games/movies. After calling Customer Support, they suggested that i do a hard reset. This did seem to solve my problems, so here is the procedure per Sony CS. I would consider this a last resort troubleshooting procedure.
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
Jan 07, 2011 | Video Game Consoles & Games
I have been playing COD Modern Warfare 2 a lot recently and want to install it on my hard drive for a quieter Xbox and less "strain" on the disk. I would just like some clarification: 1. If I install my...
1: No you won't
2: No you won't
Installing on the hard drive is just supposed to make the game run a bit smoother as the console has less steps to take to reach information (rather then processor to hard drive to CD-Rom, involving 3 steps, it's Processor to Hard Drive) This will provide a smoother gaming experience for you, without sacrificing game saves or other game information.
Aug 12, 2010 | Microsoft Xbox 360 Console
Ps3 hard disk file is corrupted
This problem always happen when you switch off your console while it is saving data or reading data from the HDD, so your HDD file system damaged, in order to solve this problem you need an external SATA 2.5 hard disk case, extract your PS3 hard drive and insert it in the SATA 2.5 case, plug your hard dist to a computer, you will find that the whale hard disk is unallocated, so format it with FAT32 or NTFS using your computer, after that return your hard disk to your PS3 console, now, your PS3 console will recognize it, and it will ask you to format it, say YES!!... congratulation your PS3 console is working now
BUT REMEMBER THAT YOU WILL LOSE ALL YOUR DATA IN THE HARD DISK INCLUDING YOUR SAVES, IMAGES, MOVIES AND ALL YOUR STUFF
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
Corrupt HDD
try formating in another ps3. you will lose all data but it will solve hard drive issue
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hard drive is saying its full when it shouldn't be
When you install a game it can sometimes install the whole game so theres no loading issues. (e.g grand theft4 3gb ish) if you go into saved game data it should tell you what games are installed, if you hit triangle and select info. it will tell you the size of the file. delete any games you dont use, and dont worry about your saves as they are in the game saves section.
Jan 29, 2009 | Sony Playstation 3 (PS3) Console
Data support
IF the sandisk is not formatted as Fat32 then the new PS3s will not recognize it. To format to fat32 follow these steps:
1. Transfer all the data onto a PC or another thumb drive.
2. go to START, CONTROL PANEL, ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, and select DISK MANAGER on the left hand side options. Select the external drive and read the "File System" type. If it says "NTFS", right click the disk and select "Delete Partition".
3. Reformat the drive as FAT32
4. Once you are SURE the partition is FAT32, open "My Computer" and double-click on your empty external hard drive. Now, you will want to create a folder system identical to that on the Playstation 3. Right click to create a new folder and name the first folder "Photo". Do this for "Music", "Video" and "Game". When you are finished, you should have 4 folders total in the hard drive. Each folder should (at this point) be empty.
5. Now transfer your saved information into the correct folders, safely remove the drive, and you are ready to go.
Jul 23, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 60g
well your ps3 might be bad if you buy another hard drive it might fry again
Feb 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
