Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Front loading washer does not advance past the rince cycle
The washer fills and goes through the wash cycle but will not  drain or rinse
  • Anonymous Mar 13, 2014
    NOT SURE IF IT IS USING ENOUGH WATER FOR WASH AND RINSE
  • Anonymous Mar 31, 2014
    Will not advance past wash cycle
  • Bosch Master
  • 3,463 Answers
Check and clean filter, it is usually located behind a plastic panel at the bottom front of the washer, remove cover and unscrew the filter cover anti clockwise, pull out and clean, replace and test, if it still does not drain, then possibly pump blocked or faulty.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
The washing machinge is not completing the complete cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't wash
Hi!
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
    288 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
