Question about Toshiba 32HF73 32" TV
Blurred picture i have replaced the flyback and the static is gone but the picture is still blurry i have adjusted the focus screw and still blurry could it be the hoz transiter
  • 252 Answers
The problem of you tv is the CRT socket ,replace the socket.
Posted on Jan 26, 2009
How can i adjust settings for blurred pictures on Samsung ES15
That would depend on why the pictures are blurry.
If the pictures are blurred because of camera motion, you need to either use a faster shutter speed or place the camera on a tripod or other stable support.
If the pictures are blurred because the subject is moving, you need to use a faster shutter speed.
If the pictures are blurred because it's out of focus, you need to ensure that the camera is focusing on what you consider to be the subject, not what the camera chooses.
Aug 19, 2013 | Samsung SL30/ ES15 Digital Camera
Picture blurred
blurred picture can be adjusted,and sometimes replacing of crt socket will solve the problem.
this is tricky so i've advice you to follow what i've said strictly.
Open the back cover of your set (make sure that you unpluged the unit first).
Look for the flyback transformer (it has a sunction cup connected to the picture tube).
You will see an adjustment knob on it, it mark focus but wait before touching,mark it with your pentel pen,marking the original location of the knob is important because that is the factory align.
After marking get an screw driver w rubber insulator as a handle to avoid an electric shock,this will be used to adjust the focus on the flyback knob.
Turn on the unit and hooked it up by your dvd player.
Play the dvd so that you will see a picture on the screen.
Pause it with a picture with characters.
Now you can see the blurred picture?
Try to adjust the focus on the flyback back and forth minimal turn only.
There's a reaction?Yes- continue to get a perfect picture and youre done.
There's a reaction?No- back the knob on its original position.
Your crt socket is faulty.
try some helped of your technician or people knowledgeable of disoldering and soldering technique.
Pull the board on the crt socket.the socket which attached to the tube is the one you are going to replaced. I've adviced you to observe first and familiarized what are going to dis-assemble because you will do the same when you replaced a new one.
After replacing your crt socket,picture ok?Yes-you're done
After replacing your crt socket,picture ok?no-picture tube is faulty.........
Jan 02, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blurry picture
Ok, if you require Fly back Transformer for your Toshiba TV, its available in Part Store.
Static noise and focus issues are related to fly back.
Oct 02, 2008 | Toshiba 32HF73 32" TV
Blurry screen
There is a focus adjustment inside on a part called the flyback transformer. It's located toward the back of the circuit board, and you'll know which part it is by the red cable going from it to a connection on the picture tube. The flyback generally has two small adjustment knobs on it. The focus knob is the upper one. Slightly turning this one way or the other may improve the focus a bit, but usually a sudden loss of focus means either the flyback or the picture tube has failed. Either of these is cause to treat yourself to a new monitor. You can buy 17-inch flat screens now for less than $150 at regular prices, and sometimes you'll catch a good sale at the office stores.
If you choose to try the focus adjustment, BE VERY CAREFUL!!
1) You have to remove the back of the monitor and work with the power on. Parts inside, especially the picture tube, can give you a very nasty shock AND EVEN KILL YOU.
2) Be very careful where you are putting your fingers when working on a live set. Make sure you have a safe grip on the adjustment knob first, THEN look at the screen while you adjust it. Don't go blindly reaching around.
Aug 31, 2008 | HP Compaq FS7600 17" CRT Monitor
RCA r56wh78 rear projection screen is blurry
if you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blurry Image
Congrats on changing the fly and getting it to come on. If it is a sony as it looks at the top of this page (accurate model?) need only to adjust focus and/or the horizontal static control. can't tell you where the horizontal static control is exactly but there are large wire associated. If not a sony then adjust the focus on the control bottom control is screen or for brighter picture.
Mar 16, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Blurred picture with lot of static
This model has a chronic problem with the crt socket arcing and causing this problem. The only true fix is to replace the crt socket locate on the small bd. that plugs on the back of your picture tube. You can however have some success by locating the focus control on the flyback transformer and slighly adjusting it until the unit stops arcing. If you are not familiar with high voltage safety then please have a qualified service tech perform this repair.
Jan 28, 2008 | Emerson EWF2004 20" TV
Blurry picture
adjust the flyback focus of your tv
just look at the flyback and you can see there the focus and the adjusting for the screen.
thats only what i know at least maybe it can help =).
Sep 23, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Sony TV with blurry picture
blurry picture is mainly due to focusing voltage is not proper. solution 1 check & adjust focus control on flyback. 2 check crt base for loose. 3 wire going to focus control on crt base got disconnected due to foreign materials deposit on it. 4 if tv is old possibility of crt getting weak.
Sep 20, 2007 | Akai CF2791 27" TV
Toshiba 32HF73 32" TV Logo
152 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
