New techwood tv can't get to switch from standby
Just trying to set up my new techwood 32832 tv, put digital aeirial where manual says and tv is just flashing blue standby button constantly. tried turning tv on with remote and with controls on tv and it is doing nothing. any advice please?!
  • Anonymous Jan 25, 2009
    techwood 32832 digital tv wont switch on from standby tried with remote and controls on the tv but no luck
SOURCE: I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Posted on Apr 10, 2008
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
  • 55 Answers
SOURCE: My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Posted on Oct 06, 2009
SOURCE: Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Posted on May 05, 2010
Can techwood 32832 t.v be wall mounted? 32 inch screen
Yes this T.V. can be wall mounted.
Buy a T.V. mount with standard VESA mounting. all mounts will state the range of T.V.s they will fit. Do not buy one too large because parts of the frame will stick out past the T.V. looking unsightly. or too small It may not properly support the T.V.
Jan 23, 2017 | Televison & Video
Techwood 32832 TV went black and now won't turn back on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 09, 2016 | Televison & Video
Techwood TV 37I asked for a set instructions to be sent by download was wondering how long does it thank you
Hello Graham
usually it depends if someone wants to pick up your request, or in some cases they try, can't find anything and move onto another question, in the hope that someone else can help you.
I am one of the manual or instructions experts, but in reality, I am just good with search engines. From a quick search, I reckon that you are not actually giving a full model number. That looks like '37-one', but Bing reckons it should be 37-letter I. However looking at the other Techwood model numbers they are much longer. Look at this;
Seems they are actually made by Matsui and badged Techwood?
This maybe that your television shows 'Techwood 37i' on the front, but the full model number is on the rear near the mains cable. It will also have a serial number but we don't need that.
All you have to do is Google
make model manual
make model instructions
The top site on the link below 'manualslib' is the best one. Stay away from any that ask you to download anything, or any that show a link in a PDF file. The don't have you manual and are just 'clickbait'.
Post back as a COMMENT if you need any further help, and please don't start a new post to reply to a question.
Fixya moderator
Jul 01, 2016 | Televison & Video
Techwood digital tv model 32832
It sounds that there is some loose solder terminal/s at the main power supply regulator board. Contact any service technician.
Gopakumar Gopalan Google
Mar 09, 2014 | Televison & Video
Television reset
Hi les
Try to apply fine tune..
Jan 18, 2014 | Televison & Video
Our new techwood 1020 digital video recorder, bought for our Golden Wedding, will not respond. We get a picture for twenty minutes and then the picture breaks up. Our TV engineer came out and we had a new...
It could be a software problem: our shipped with version 0.5 (see help menu to see version). The helpdesk told us how to force an upgrade (if it's higher than version 2 it's probably upgraded itself already). " Go to Help menu. Type 1397 within 5 seconds to get to Engineering menu. Select option to "Force OAD". Put into standby for a couple of hours. Then Switch off for 1 minute. Rescan channels. It worked on my box "
Nov 16, 2009 | Televison & Video
Televison & Video Logo
454 people viewed this question
Top Televison & Video Experts
