Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Problems with washing machine cycles
I currently have a Bosch WFF200L washing machine. It does a main wash however does not proceed to the next cycle and continues to carry on with the main wash procedure. Any advice? Many thanks, Peter Lee
  • Anonymous Mar 30, 2014
    I am able to get to a P01 and C02 diagnostic test what is the next step in resetting my control panel/
Does it heat up? if not the element has gone and needs replacing. try it out on a cold 30 wash to see if it goes through if so element probs.
Posted on Jun 01, 2007
SOURCE:
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
BOSCH AXXIs - My wash cycle never progresses to rinse and drain.. just stays on wash forever!
It seems that the main controller could be the culprit but this requires you to counter check and confirm the fault before you can proceed to replace. It will be best to check all the connections and reset the pins and connectors. If the cycle goes through well in many modes it is adviceable to use as much by alternating the cycles than to replace the controller if you can manage..
May 31, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFL 1660 Front end loader washing Machine , Washing Cycle fine , Into spin Cycle , there is a huge knocking sound , and then the Circuit breaker supplying the apparatus trips ???
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Feb 28, 2009 | Bosch Washing Machines
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
the heater element may have gone and the wash continues waiting for it to heat up and satisfy the thermostats b4 advancing.
May 29, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
