Question about GE JVM1630 Microwave Oven
Microwave will not heat
I have an JVM1630bb004 microwave it comes on normal but eill not heat any advise
  • 1 more comment
  • dansan Jan 13, 2009
    ge spacemaker model jvm1630 will not heat, everything seems to work but the microwaving/heat. Vent fan, lights,, timer etc. all appear ok just does not microwave. magnetron terminals are not open, and terminal is not shorted to its housing.. .
  • William Miller
    William Miller May 11, 2010
    Thanks for the model number.
    When you hit Start to
    cook, do the cooling fan and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • Natale Nov 01, 2012
    model JVM1630BB004 recently stopped heating. I only cook simple things and tried adding three minutes. The bottom of the microwave heated so I thought whatever it was got fixed. But there is a burning plastic smell and now a noise. I tried taking down the circular attachment on the roof and clean around the vents, let it dry and tried it again. There is a noise and for ten seconds tried to heat a cup of water. the noise and again the burning plastic smell is scaring me. What do you mean an energy leakage test must be performed by tech. Have some of us been exposed to dangerous waves because microwave does not heat when door is closed
  • GE Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
MICRO WAVE DOOR FOGS UP WHEN USING IS THAT NORMAL
A Microwave Oven works by heating water/moisture in food: if the boiling action (e.g. when boiling water) is greater than the oven exhaust fan can cope with, then the inside will steam up and fog the door glass: this is usually OK and 'normal' (this is actual the advise in cleaning up the interior of a microwave oven - steamy soapy water - see your manual).
Hope it helps.
May 16, 2011 | Hamilton Beach Microwave Ovens
GE Profile spacemaker 1800xl microwave it starts but doesn't heat, what is your best advise
The power supply to the microwave unit has burned out. This unit normally is under warranty for seven years. The real problem is that unless you take the unit into a authorized repair place it will cost you almost as much as you paid for the microwave when you purchased the unit to have a repair company to come out to your home to fix your Microwave .This happened to me and I just purchased a new microwave and got rid of the old one. If you can find a authorized repair shop , stake it in before you purchase a new one. Sorry I could not help not even for myself. .
Dec 24, 2010 | GE XL1800 1100 Watts Microwave Oven
Microwave not heating. Is it because i dont set a heating time and open the door while its heating. Please advise how i can fix the microwave. Can i do it myself. Thank you,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | Microwave Ovens
No heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
djghn
May 25, 2010 | Sanyo EM-S5002W Microwave Oven
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
My microwave oven is not heating the food
HI, you will need to replace the heating device. This device is called the Magnetron and, it will cost you about $133.00. This is a repairable issue but, you will need to call for service. I do not recommend installing this device if you are not familiar with handling this type of tech.
May 30, 2009 | Frigidaire FMV157GM Microwave Oven
GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Above Range GE Microwave not heating
Try disconnecting the power line from the microwave ad then reinstalling it after a few minutes.. then try heating up a small cup of water.. allow 1.5 minutes on high power. it should get very hot or boil.. if it doesn't get warm or hot then you may have a bad magnetron ( the tube that produces the microwave energy that causes things to heat up or a bad filament transformer that is required for the magnetron to work.In either case, if it fails to heat anything, I would go back to home depot and insist they send someone out to address the problem. many of their appliances come with a one year warranty but you might want to call the store and ask someone there about normal applaince coverage ( less extended warranty) and what they normally offer. An inquiry costs nothing..
Hope this helps..
Sep 17, 2008 | GE Microwave Ovens
Microwave doesnt heat anything.
it is the door problem it seems to be known issue per target sales guy he advise to call emerson since it is past 90 days for target to return
Jan 19, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
GE JVM1630 Microwave Oven Logo
295 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
