Can you please assist me how to install XP or any OS in hp laptop which has os windows vista?
  • Anonymous Feb 10, 2009
    key code not work with my disk
  • Hi, please clarify me what is the actual problem. Which disc you used? have you try other disc, or what happened when you try to install it?
  • 33 Answers
You will need to get a copy of XP or another operating system on a CD. Put the CD in and then turn the laptop off. Turn it back on. Windows XP Setup will probably start. If so, skip the next paragraph...
If it does not, and Vista starts up again, then shut it back down, turn it back on again, and when you see the very first screen that comes on with the HP logo, press the F10 key. Then you will need to change the boot order so that it will read from the CD before loading Vista. To do this, press the right arrow key until you're at the tab labeled Boot. You then need to change the order of the boot devices so that the CD drive appears at the top of the list or as number 1. It will probably be called DVDRW or something like that. Then go to 'exit' and make sure you use the option that saves the changes you've made. It will then reboot again.
Once XP setup starts, use the option that will reformat (erase) your hard drive and install a fresh copy. Obviously you will want to make sure you have any files or information that you want to save backed up somewhere. The reason for this is that you don't want to end up with both XP and Vista installed at once (while it may sound like a cool idea, it causes WAY too many problems, believe me). Then it's pretty simple, it will go through an install process and at some point ask you to remove the CD from the drive and reboot. Make sure you do, because otherwise, it will reboot with the CD still in, and this will start the install process over again from the beginning. After this reboot, just follow the on screen instructions to set it up. And it will probably reboot one more time, and then start up normally. Congratulations.
Posted on Jan 07, 2009
  • 59 Answers
1) You must have a Bootable O/S CD/DVD
2) You will have to do a clean installation of O/S
If installing Win XP be sure that there are Drivers for the Laptop available for Win XP. If not some of your hardware will not function properly.
Windows xp hp pavilion dv6000
You may be trying to install the 64bit XP on a 32bit system. Make sure you're using the correct architecture OS for your CPU
Aug 04, 2013 | HP Computers & Internet
Os problem
hi..yea but download 1st all drivers support for what kind OS/Windows are your using..good luck and have a nice day
Jun 25, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
Sound driver problem in Compaq C740TU / O.S- Window XP
Hi there.
Your audio is "Conexant High-Definition Audio"
Download and install this driver and see if will work as HP don't supply a driver for XP
Post back if the driver does not work and don't forget to restart the laptop after installation >>>>>>
http://asia.cnet.com/downloads/pc/swinfo/0,39000587,50002418r-39535777s,00.htm
Good luck and thanks for choosing FixYa!!
Jun 09, 2009 | Compaq Computers & Internet
I Want to change my vista os to window xp for my laptop Hp Pavillion dv4 1240 tx.
yes. you can change vista os to window xp. but before the installation make sure does hp provide the driver all of those which your are going to use. for the driver detail log on www.hp.com.
once you make sure about the drivers , then arrange the XP bootable cd . and now try to install xp on your system.
Mar 24, 2009 | HP dc7800 Business Desktop USDT Alternate...
HOW TO INSTALL XP IN VISTA OS OF LAPTOP HP PAVILIION
Hi there.
The only way you can install XP on a Vista machine is to install "virtual XP" onto Vista using Virtual PC 2007.
Here is a site that will take you through the procedure step-by-step and gives links to download Virtual PC and install it onto the machine.
Please be aware that some drivers may not work whilst using XP when you have it installed.
http://lifehacker.com/software/windows/geek-to-live--run-windows-xp-inside-vista-with-virtual-pc-238071.php
Have fun, good luck and thanks for using FixYa!!
Mar 23, 2009 | HP Pavilion DV6700T Notebook
I'm using HP Pavilion dv2500t PC Notebook ,in that vista OS is there I want to instal Windows XP So I need Drivers for my Notebook.Where can I get drivers?
hello...download the required drivers from the fallowing link
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3369421
Dec 06, 2008 | HP Pavilion dv2500t Notebook
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
XP replacing Vista on HP laptops and on other laptops - What Can I do
Bro you first need to disable the SATA Native support then you can install Windows XP/2000 or other legacy OS!
Dec 08, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
