Question about Acer TravelMate 8200 Notebook
New 6600 mAh battery won't charge
7800 mAh battery that came with computer doesn't hold charge after 2.5 years (understandable). Cannot find much except 6600 mAh for replacement. 2 of those charged, then discharged all the way; then they wouldn't charge back beyond what registered as 11%. Unplug the AC / charger, and comp died -- i.e. battery wasn't charged at all . 3rd replacement 6600 mAh won't even charge all the way up one time. Only registers 11% . Some diagnostic in Ubuntu shows old battery as "old or damaged" with 33% capacity. No such message with the replacement. Can 3 or more replacement batteries all be bad, or is there some known problem with the Acer Travelmate 8200 's charger?
  • mj_smith383 Jan 09, 2009
    Thank you for all the helpful ideas. We were able to find a 7800 mAh 9-cell battery, which is working perfectly. Turns out apparently the problem is with the 6600 mAh battery -- at least for my machine. Anyone with this same problem, or needing to replace their original battery -- I recommend looking for the Energy+ 7800 mAh battery, and not settle for the lower capacity one which may cause this problem.
  • Hi
    Normally AC adapter problems are rare especially when your laptop working fine when plugged on it.
    just confim the pin contact betwwn computer and battery (at laptop) is there any sign of kink or bend?
    if one of the pin dented or squeezed, that is the causes but if it's ok it could be your battery.
    2nd and 3rd Replacement of battery, can you confirm me that you are buying it from outsiders or from trusted store or have you ever opened the battery? did you buy from the same store/person?
  • Acer Master
  • 32,281 Answers
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Posted on Jan 07, 2009
Pocket juice max 7800 mah cuts on then cuts off after 5 seconds with a full charge
sounds like your battery has lost its ability to charge. It could be damaged from either getting too hot, or dropping it. Age also takes a toll depending on the quality of your battery and the brand name also determines how long your battery will last if it is a rechargeable battery then it is limited to a particular amount of times being charged before it will no longer charge
Dec 07, 2014 | Cameras
Tip
High Quality VGP-BPS13 Battery,Replacement Sony VGP-BPS13 Battery 4800/ 5200/...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Nov 20, 2010 | Computers & Internet
Supertooth disco speaker issue
You need a new battery that supplies the full 2400 mah to unit. Batteries do wear out and the 1800 mah is not going to cut it.
Aug 24, 2017 | Audio Players & Recorders
Does the value of a battery capacity(mAh),larger than that specified for a laptop,mean any damage when used with it?
No it doesnt.. It just means that the battery can hold a larger charge.. I.E. the laptop will run longer then one with a lower mAh..
Mar 14, 2013 | Battery Biz Computers & Internet
New battery 6600 mAh does not charge anymore
It is possible it is a bad battery again. Also could be a bad solder joint on the DC jack or bad AC adapter. To test power off and unplug the laptop, remove the battery. Now plug in the AC and power on the PC. If it comes on, gently wiggle the AC plug going into the PC. If it shuts off you have a bad DC jack solder joint. If it stays on the battery is probably bad or the battery connector on the PC. If the PC doesn't come on at all with just the AC gently wiggle the AC plug and tap the power button repeatedly. If it comes on briefly than off again it is the jack solder joint. If it doesn't come on at all then it's a safe bet the AC adapter is bad.
Apr 17, 2012 | Acer Computers & Internet
My acer Aspire 5741 won't charge beyond 37%
Let your computer run out of battery(until it shuts down) then plug it but don't turn it on... let it charge for about 2 hours. Post here if it worked.
Aug 29, 2011 | Computers & Internet
I have a philips se 455 cordless phone that won't hold the charge at all and was considering getting rid of it until I saw this site and read that I should be using rechargeable batteries ? Will this...
well it very well may see they rate batteries in mah normal duracells and thing are usally only 800-900 mah milli amp hours a good rechargable battery can be from 2200mah i have seen them up to 3200 mah for phones so yes a rechargable battery would last longer in the phone as they have a higher mah or in simple english longer discharge time
if it helps please give 4 thumbs up it helps me continue to help all of you thanks
May 12, 2011 | Cell Phones
Can my makita bl1830 battery be repaired if it does not hold charge anymore
This battery has a known design defect that causes premature failure. The battery is still probably good, but the safety circuit n the battery spuriously locks it, due to a bug. Once locked, it won't charge in the Makita charger (flashing red and green lights). Makita knows about this problem but so far is not actively recalling the batteries. Makita will replace the pack if the charge count is under 150 (some people say 300?) regardless of warranty status, but you have to take or mail it to a Makita Service Center -- the dealers won't handle this unless it's in warranty.
http://www.makita.com/en-us/Modules/Service/ServiceCenters.aspx
If Makita won't fix it, you can try to repair it. If the red and green lights are flashing, the battery is probably locked and cannot be repaired in a way that will let it be charged in the Makita charger (but it can be charged in off brand chargers). Buy a clone charger on eBay for $60 and try it. If it charges, just use it, no repair needed.
Be aware that lithium batteries do lose capacity permanently at a rate of about 20% per year. So, 3-6 years is about the best battery life you can expect - from date of manufacture, so if it sat in the store a while that adds. Makita derates the cells to allow for some shelf life (down from 2400 Mah to 1500 Mah rating).
If the battery is weak, and only gives brief usage, you can replace some of or all of the cells in the battery. These are expensive and worth repairing. See this video:
http://www.youtube.com/watch?v=Z5taguEdlkY
If just 1 or 2 cells are weak, you can replace them with the same Sony 18650 size 2400 Mah capacity battery, green sleeve. The Sony's are not sold retail, and are hard to find other than from another Makita pack or from some laptop packs. If more are weak, you're better off just replacing all of them with new 18650 2400 Mah (or higher) batteries with tabs. Look for Tenergy or other quality brand.
Hope that helps.
Nov 02, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have dell inspiron 1100 with 6450 MAh battery which is death already, i am looking to buy new one, before doing it i would like to get some advise what is the difference between 4400 MAh, 5200 MAh, 6450...
MAH is short for Milli Amp Hr...
4400MAH battery - short time for the battery to discharge....it may work for 4 to 5 hrs....
7800MAH will work longer for say 8 to 10 hrs.....
also depends on what applications u use...if it contains many graphics and you keep watching movies then the working hrs gets further shorter....
hope this clarifies....offcourse...the 7800 will cost you more...than the 4400....
as far as what is suitable to you laptop check the mfg website or the manual that came with the notebook...some times...the power adpator also gives the battery specifications that must be used...
reg
let me know...
Mar 12, 2010 | Dell Inspiron 1100 Notebook
Open Questions:
Acer TravelMate 8200 Notebook Logo
278 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
