Question about Acer Aspire 3003LCi Notebook
Keyboard and Touchpad not working
My keyboard and touchpad are not working. They might work for a minute or two after reboot, but then die. Does this sound like a PS/2 problem on the board or bios? How do I fix?
  • teddhead Mar 22, 2009
    My Acer Aspire 3003LCI touchpad is malfunctioning also, Windows XP loads, but touchpad will not move arrow to click name to begin.
When the batteries on that laptop no longer hold a charge it will cause teh problem you indicated. Remove the battery and restart from the AC power to check. If that fixes the problem you need to go into the devive manager and turn off the Microsoft battery manager. This will allow you to reinstall the battery without the problem.
Posted on Jun 03, 2009
  • 458 Answers
Sounds like the wrong drivers..... If the mouse/touchpad work until the windows splash screen and desktop come up, then you have the incorrect drivers, windows will boot up using the default supplied drivers, which is why they work when you innitially turn on the computer..
Try possibly booting to "last known good configuration" to correct the drivers
Posted on Jan 07, 2009
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
Keyboard working fine, touchpad is not working at all. have a mouse plugged into usb port. plugs from keyboard are in correct ports.
You may have to install the driver software for your keyboard to enable the touchpad to function. Did the keyboard come with a special installation CD? If not, visit the Solidtek website to download the software there.
May 05, 2011 | Solidtek Keyboard, Touchpad
Hello! After I changed the keyboard (my daughter threw some water over it), the touchpad stopped working. I mention that the touchpad worked after the water was thrown on the keyboard. What can I do? Thank...
first felt sory abou that...
try to dry inside your touchpad it can make water can make short on touchpad. for keyboard the dirty makes your keyboard mallfungtion
Jan 14, 2011 | ASUS Eee PC 900 PC Notebook
HP Pavilion DV1000 touchpad and keyboard freezes
sometimes its a hardware driver software and OS driver software conflict on touchpad. if after OS installation the touchpad is already detected, no need to install the touchpad driver. try disabling the touchpad driver you installed. hope this helps
May 30, 2009 | HP Pavilion dv1000 Notebook
My computer tayping rong words
Hi
Check the device status in the device manager.
Please check if the keyboard and touchpad are listed correctly without any yellow exclamation marks.
But you should try to reinstall the drivers again even though the keyboard and the touchpad were recognized properly.
In this case I would recommend removing the keyboard and the touchpad from the device manager and then you should reboot the notebook once again.
After Vista has rebooted the both devices should be recognized again and should work. To find the drivers try asking the online chat at toshiba for the driver if its not listed in the driver download page.
Mar 02, 2009 | Toshiba Satellite A300-0CF035 Notebook
System freeze after booting the keyboard & touchpad unfunctional
Delete the keyboard driver in the Control Panel and reboot. Windows will reinstall it. Then do the same for the mouse driver.
Jan 17, 2009 | Computers & Internet
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Touchpad
sounds like software encoding error nothing you or  i can do cept take it in to a place like infotech i like them they help me alot
Oct 27, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire 3003LCi Notebook Logo
205 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
