Question about Canon SmartBase MP730 All-In-One InkJet Printer
Does not feed paper from the back
My cannon printer will not feed paper. I have roller cleaned several times but it still does not feed. Help??
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
Paper fee picks multiple pages. Normal paper. Have tried all the different platen gaps. Help!
Epson printers use a set of rubber rollers to pick up the paper. Some paper can leave a slick deposit on the rollers, causing mis-feed. I spray some cardstock lightly with alcohol, and run it through several times (use the paper feed button) to clean that off.
Also, check the paper itself, if the sheets stick together, "fan" them before putting them in the printer.
Feb 15, 2016 | Epson Stylus Pro 3880 Inkjet Large Format...
Cannon MP 250 crayon stuck between rollers
Description
Cleaning the Paper Feed Roller - MP250 / MP270
Solution
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and remove any paper from the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Clean the Paper Feed Roller.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4. Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
If the problem is not resolved after cleaning the Paper Feed Roller, contact the service center.
NOTE:After the cleaning is completed, press the Stop / Reset button to return the LED to the copy standby mode.
Oct 28, 2017 | Office Equipment & Supplies
I have a cannon mp 240 bought it 7 months ago have barely used it, just purchased 1st set of ink cartriges. have printed maybe 4 pages since replacing.. Now says out of paper, wont feed sheets in. help!!
Check the rollers that feed the printer paper through. Use compressed air to clean out the printer and rubbing alcohol on the rollers once you clean them. If the rollers aren't grabbing the paper, then maybe a gear is not working properly.
Canon offers a one year warranty, take the printer in and get them to service it instead of trying to fix the problem yourself.
Sep 01, 2009 | Office Equipment & Supplies
Canon i9900 on power up after boot, i am getting get 2 flashes on the orange light. I know its related to paper detection. is this a minor or major problem?
Should be minor, just says no paper, load paper and press resume. Sounds like a print job in the buffer or it wants to advance a sheet of paper thru. Paper not feeding could be major though.
Jul 30, 2009 | Office Equipment & Supplies
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
PIXMA MP780: Multiple pages feed together
Most paper feeding in printers is done via rubber rollers. These rollers get dirty and over time, the dirt glazes on to the roller. When this happens, the roller loses its grip. If you look at the rollers they will actually look shiny. After a while the rubber will dry rot and it becomes a more frequent problem. Try the following:
(EASY/LIGHT CLEANING) Get some inkjet cleaning paper at you local office supply. This is usually a thick absorbent paper that you spray with a cleaner and "print" with the wet page.
(MEDIUM) If that fails, unplug the printer and try using rubbing alcohol or ammonia to rub the rollers with a terry cloth. Be sure to rotate the rollers and get them all the way around.
(HARDER/BE CAREFUL) For hard glazed dirt, you may want to carefully use an hobby knife to scrape it off the rollers, being carful not to damage the rollers. Follow up with alcohol cleaning described above.
Feb 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannon copier
Where is the machine saying the jam is located? Does the paper even start to feed? Does the paper feed to the next feed area? If the machine sounds like it is feeding ( trying to feed) and the paper is still in the tray --- clean the feed roller/ tire with rubber restorer or a high alcohol base cleaner. IF the paper is fed part way out of the tray to the long ( most of the time) black reg. roller and now farther --- clean the reg. roller. There is always the chance that you have a bad feed motor or reg. motor. Also look to see if an actuator / switch has been pulled / knocked out of position. They is is small cradles and can be snapped back into place.
REG = registration
Jan 06, 2009 | Office Equipment & Supplies
Hp 1210 paper will not feed
Hi ihimc1, over time dust and paper fibres can cause the rollers to stick, which can result in the paper not feeding please take these steps below to clean the rollers.
Turn off the all-in-one.Unplug the power cord from the back.Remove the rear access door. Clean the rollers one at a time using a clean cloth that is slightly dampened with water. Rotate the roller to clean the entire surface. Verify that the three paper feed rollers on the rear access door are clean and rotate freely.
Reinstall the rear access door and then plug the power cord back in.Turn the all-in-one back on.
Nov 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper won't feed, HP printer dock series 3
I had this problem (among many others with my printer). I found that just cleaning the front roller with a damp paper towel fixed it. Wipe it carefully and let it dry before reloading the paper. The rubber on the roller seems to lose it's ability to pick up the paper if it sits unused for any length of time, so wiping it with warm water and drying it works. Good luck. Lynette
Aug 28, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Canon SmartBase MP730 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
